So after the antics of a headlight bulb blowing on Saturday and literally starting to burn after it had blown, smoke and everything coming from the headlight (to the extent I has to stop and disconnect the bulb as I was worried it would catch alight!), a break light has blown out now.
No problem normally, but is it just me or is removing the rear cluster nigh on impossible? Why make it so hard just to change a ****** bulb!I have literally put my entire body weight behind removing the tail light and it wont budge! It cant be that hard as loads of you lot have changed your tail lights
Does it hinge on anything or are there just clips holding it in place?
