Badger5Volks Autos
    Jan 2011
    119
    audi a3 8p 2.0 tdi 2004 fault codes, help!!!
    Hi guys, ran a scan on my audi last week and everything was fine, only had one fault which was an ABS sensor, Today i noticed the coil light on the dash flashing and my brake lights are on constantly! i ran a scan again with vag com and i now have loads of fault codes! Please can someone help me with this, could all of these fault codes be related to the same problem? the main problem is cent conv electrics module? i have listed the faults i am getting. Would really appreciate it if somebody could shed some light on this. Here are my fault codes:
    1 Fault Found:
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 000 - - - MIL ON
    Freeze Frame:
    RPM: 903 /min
    Torque: 146.0 Nm
    Speed: 22.0 km/h
    Load: 14.5 %
    Voltage: 13.83 V
    Bin. Bits: 11000110
    Torque: 160.0 Nm
    Bin. Bits: 0 00 0
    Readiness: 0 0 0 0 0
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Revision: 00030000 Serial number: 00000000388879
    Coding: 03884F00A2141000000000000000000000
    Shop #: WSC 00000 000 00000
    VCID: 3B7EB21A030D
    Part No: 8P2 955 119 C
    Component: Wischer WWS Audi350 0180
    Coding: 16711696
    Shop #: WSC 00000
    7 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    004 - No Signal/Communication - Intermittent
    01320 - Control Module for Climatronic (J255)
    00483 - Control Module for Auxiliary Air Heater
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    00988 - Lamp for Brake Light; Right (M10)
    012 - Electrical Fault in Circuit - Intermittent
    00466 - Control Module for Steering Column Electronics (J527)
    01332 - Door Control Module; Passenger Side (J387)
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 2400103B179A62
    Coding: 3D0F0B42070101
    Shop #: WSC 06435 000 00000
    VCID: 2648736EE88F
    2 Faults Found:
    00470 - Combination comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 32
    Mileage: 130446 km
    Time Indication: 0
    Date: 2010.08.10
    Time: 13:41:28
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Reset counter: 106
    Mileage: 136267 km
    Time Indication: 0
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000048
    Shop #: WSC 00838 210 00659
    VCID: 3A70B71E0C37
    1 Fault Found:
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    008 - Implausible Signal - Intermittent
    Hope you guys can help me with this. i just want to know what parts i need to fix all the faults. I cant understand why i have all these errors and last week there was only one. Any help with this would be great.
    Chris
    Jan 2011
    105
    Clear the codes, and see if you can give it a short drive, then re-check them. You should get less, more accurate codes. It might help to narrow things down a bit.
    2007 8P S-line 140 TDI BKD Sportback. Milltek De-cat, Cat-back, AMD remap, 312mm Brake conversion, Bose, Alcantra Leather, BT, Dark Headlining, Piano black trim, courtesy light pack.
  1. 2004 A3 TDI 140 Fault Codes
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2012, 19:33
  2. 2.5 tdi engine fault codes help please...
    By Kostas in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th June 2011, 02:53
  3. 2005 A3 TDI - pile of fault codes
    By timcoupe in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th September 2009, 12:46
  4. Audi A6 3.0 TDI QUATTRO 2004 Immobiliser fault
    By marabass in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2009, 12:46
  5. fault codes A3 TDI
    By Evstdi in forum Diesel forum
    Last Post: 14th February 2006, 11:35
