Badger5EM Tuning
Results 1 to 12 of 12
    Dec 2009
    Durham
    76
    Boot and Glove Box Light
    where are the fuses located for these?
    i have recently changed my heating resistor and i took my glove box out. now i have an air bag light and the glove box light doesnt turn on.
    has anyone had this problem and know a fix?
    also my boot light doesnt work. i have changed the bulb but still no luck.
    please help guys.
    thanks
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    On the side , near your right leg when your driving ..
    Dec 2009
    Durham
    76
    I know that. there doesn't seem to be a fuse there.
    Dec 2009
    Durham
    76
    okay glove box light is now sorted
    now the boot light?
    anyone share some ideas?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    buld gone ? test connetion i have put a guide up em tunning light upgrade showing where the clips are placed so it dont get broken
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    warrenlord's Avatar
    Apr 2010
    778
    Can someone confirm this ? The boot light needs a canbus Smd bulb but the glove box doesn't ?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    think its both
    Jun 2011
    Wellingborough
    1,156
    Quote Originally Posted by warrenlord View Post
    on an A3 only certain bulbs will work, i tried many before working out the right voltage to get it to work.
    the glove box you will be fine to use a normal led as the circuit turns completly off when the lid is closed.
    this led upgrade will work with no problems in there - VW/AUDI boot lamp LED SMD UPGRADE/ Golf mk4 and A3 Boot | eBay
    JPK
    May 2012
    278
    I have the same problem. Have installed tm tuning leds and all are fine except glovebox and trunk.
    Wont be anything to do with the leds as both of those lights with stock bulbs were not working before i swapped out to the leds.
    Ive checked fuse but there only seems to be one for interior lights and thats fine.
    JPK
    May 2012
    278
    Stock bulbs were fine also. Not blown
    JPK
    May 2012
    278
    Any ideas?
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Im having same issue, did you get this fixed?
  1. Glove box light retro fit and puddle light information
    By pns2007 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 17th April 2014, 11:13
  2. Replies: 1
    Last Post: 25th November 2011, 22:56
  3. Glove box light not working
    By Alan H in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2010, 22:02
  4. Glove box light
    Last Post: 31st August 2010, 22:18
  5. boot and glove box lights
    By tj1978 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2008, 10:19
