JMB RetrofitsChris Nott
Results 1 to 30 of 30
Like Tree9Likes
  • 1 Post By s3ollie
  • 1 Post By s3ollie
  • 1 Post By warren_S5
  • 1 Post By s3ollie
  • 1 Post By S3Alex
  • 1 Post By S3Alex
  • 1 Post By s3ollie
Thread: Fuel pressure problem with S3, please help!!
    Dec 2011
    22
    Unhappy Fuel pressure problem with S3, please help!!
    Hi,
    I'm expericing some problems with my car again.
    The thruttle is not really responding and the car is shaking and it doesnt have any power.
    It takes a long time for the car to get some speed and it's like the car is drowning in fuel.
    I connected the computer and it says fuel pressure regulator 2 fail.
    And the EDC and Engine lights up in DIS.
    I'm trying to locate the Fuel ressure regulator valve, but i'm a little confused.
    Can anyone point out where to look. Post a Picture..
    That will really help.
    My Mechanic cant seem to find it.
    Some help please.....
    s3ollie's Avatar
    Jan 2007
    749
    The high pressure regulator is 3 in the pic. 3 cant be brought (new) seperatly from the HPFP. There is also a fuel rail pressure limiting/regulating valve, that is 10 in the pic however this a mechanical valve that bleeds the rail pressure if it reaches 130bar. There is also a regulator in the fuel filter again this is a mechanical valve and not electronically controlled.
    11 is the thrust sensor and is used for sensing the rail pressure.
    4 is the low pressure thrust sensor used to measure pressure in the low pressure system.
    You really need the full DTC to decided what valve is faulty
    vijays786 likes this.
    8P S3
    Dec 2011
    22
    Quote Originally Posted by s3ollie View Post
    It says:
    P2294 on the DTC is that enough to decide it?
    s3ollie's Avatar
    Jan 2007
    749
    P2294 Fuel Pressure Regulator 2 Control Circuit/Open
    Looks like there is an open curcit. You could try checking the wiring as there maybe a plug off or a break somewhere?
    8P S3
    warren_S5's Avatar
    Oct 2007
    7,163
    Fuel pressure regulator circuit open.
    I'd assume it would be worth starting with part #10, but whilst it's cheap, it's a ***** of a job as its located between the manifold pipes (from memory), so you may need a special or modified tool to do it.
    warren_S5's Avatar
    Oct 2007
    7,163
    On a side note, have you checked the cam follower recently?
    s3ollie's Avatar
    Jan 2007
    749
    Warren I think the open circuit is refering to an open eletrical circuit. 10 is a mech valve and isnt electronically controlled
    8P S3
    Dec 2011
    22
    I'm told that i need to change item 4 or 11 to get it to work. Is that possible ??
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    It's worth saying that the plastic housing containing wiring from the top of the HPFP can crack...this happened to mine last year,and basically the car has no idea of what the fuelling is doing.
    The black plastic at the top of the HPFP is worth checking over for hairline cracks.
    Dec 2011
    22
    Quote Originally Posted by S3Alex View Post
    Is this what you are talking about?
    http://i146.photobucket.com/albums/r...800/1Large.jpg
    Checked it and does not look like thère is any problems with it.
    Why is when i go to Audi and say "Fuel pressure regulator valve (open circuit)"
    They look at mé like i'm from another planet and they have never heard about this.
    And p2294 they dont understand aswell because they use another system.
    They use one letter and three numbers as code he told me. Some help....
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Quote Originally Posted by vijays786 View Post
    That picture you've put up shows a horizontal crack from side to side across the top of the assembly.
    You can actually see where there is a gap between the two halves of the plastic fitting,and the top of the assembly should be flat around the hub where the wiring harness enters....that one has a large step in it.
    This is exactly what had happened to mine and will mean a new HPFP...don't drive the car in the meantime as it has no idea of it's fuelling,and you could damage it badly.
    This is yours that you've posted I hope.
    EDIT.....I can see you've got that pic from somewhere else....would have helped if you'd mentioned that.
    warren_S5's Avatar
    Oct 2007
    7,163
    New pump is £177 from Audi dealers.
    Same thing happened to my VVT sensor on old S3 (cracked day before I was doing a road trip to Europe). Had to fit it myself and wasn't 100% straightforward.
    There are plenty of guides on here as to how to change the pump so quick search will reveal all.
    s3ollie's Avatar
    Jan 2007
    749
    11 and 4 are your high and low pressure sensors I doubt replacing them will fix you issue. From the code you have it suggests and open circuit to your regulator, this mean you have either a bad connection, a broken wire, a plug not connected or a bad regulator. You can do a output test for the regulator n276 in the engine module through vcds
    8P S3
    Dec 2011
    22
    S3Alex i'm sorry that i did'nt write that the picture was not mine, it was the only picture i could find.
    S3ollie i doubt my mechanic knows how to output test for the regulator n276 in the engine module through vcds.
    Anyway guide for this?
    I'm getting really frustrated over this problem. I will try to find out what it might be and still if anyone have some suggestions please do collaborate...
    I'm really happy that you guys help so much!
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,548
    Hi vijays where abouts are you from there are some great audi specialists through out the country that would sort this problem out for u , with out you pulling yout hair out..
    Dec 2011
    22
    hehe.. i know in UK you have great Audi specialists, but not in Sweden :-(
    I Found a guy who has the exact same problem and describes it much better then me (poor english) and the same error codes. Maybe it will help you understand the problem.
    TFSI: 008851 - Fuel Pressure Regulator Valve - SEAT Cupra.net - SEAT Forum
    Gavin0478's Avatar
    May 2010
    cleveland
    453
    have you checked the relay you replaced is correct and is not loose or any of the wiring in that area has been disturbed?
    V8 baby... oh yeah
    Dec 2011
    22
    I Have also had some problem with the relays on the car. It could'nt be a Fuel Pump Relay or something like that?
    These are the error codes for now
    P2294
    P0657
    P0444
    Earlier today
    p0657
    p0444
    p2294
    p0031
    p0036
    Dec 2011
    22
    Quote Originally Posted by Gavin0478 View Post
    We think a like Gavin. Garvin Audi changed them for me and had a diagnolist on the car. So i'm guessing he did his job. I picked up the car from Audi when they were about to close and right there it did not seem like the car had any problems. When i left the problem started immediately and Audi was closed. Now they have a long wating, because of the new year :-(
    Dec 2011
    Hello
    Hello there my name is David from the seat forum (hope you don't mind me popping in?)
    I drive a seat leon tfsi sport revo stage2+
    Anyways...
    Sounds very much the same as me mate.
    Have you checked your Cam follower
    and the piston etc? Any photos aswell?
    It's more than likely your going
    to need a new High pressure fuel pump!
    But check the other things first,
    By the way changing the follower will not resolve the issue.
    Dec 2011
    Oh some people would advise to change the thrust sensor that is fitted next to the fuel pump...but I don't think from experience its going to be this on your car.
    Its very likely to be the N275 sensor which is located on top of the HPFP HOWEVER they don't sell it as a single item, it comes with the pump as complete unit. (annoying)
    Gavin0478's Avatar
    May 2010
    cleveland
    453
    what is this cam follower issue that keeps cropping up?
    V8 baby... oh yeah
    Dec 2011
    Just a design flaw with the 2.0L TFSI engines, there is a fix for it but it involes alot of money and time + effort...
    Hmm not sure how to explain it but even on standard engines they can cause issues (where the err camshaft is rubbing on the follower)
    Cam Followers and Oil Changes – A Warning markFive GTI
    This should explain it alot better than I can... Enjoy
    warren_S5's Avatar
    Oct 2007
    7,163
    Poor quality design of fuel pump by VAG. cam lobe causes wear on the cam follower tip over time, and if you tend to rev the car the quicker they seem to fail. Worst case scenario is that the cam follower actually wears through.
    KMD do an uprated cam follower for about £70 (instead of £25 for OEM), but I'd be worried as it's harder that it may score the cam lobe. I think it's just best to change the cam follower every 20-30k as part of your maintenance programme (get indy to do it as VAG dealers probably won't want to check it as its not on service schedule).
    Gavin0478's Avatar
    May 2010
    cleveland
    453
    does relpacing the internals of the hpfp as it seems you have to do to get to stage 2 increase the wear then?
    V8 baby... oh yeah
    Dec 2011
    Quote Originally Posted by warren_cox View Post
    Hey Warren How are you not seen you on the forums for awhile! i hope you are well, I believe I was nagging you before about the Forge catch can! hehe
    Ps. I don't know anyone that uses the KMD cam follower, its way too expensive and I don't think its coated.
    Everyone sticks to using the oem follower as its still by far the best follower out there, its just annoying to change it.
  28. #27
    Dec 2011
  29. #28
    warren_S5's Avatar
    Oct 2007
    7,163
    Yes, but it seems improved with the later generation internals.
    I had KMD internals on my last car and they wore the internals of the pump so badly new seals didn't remedy the fuel leak. I had to have a whole new pump. It was a very early kit, so pre the new version with uprated coating / materials that are used in latest KMD / Autotech kits. The revisions have made them far more reliable.
  30. #29
    s3ollie's Avatar
    Jan 2007
    749
    Go in to the engine module 01 click on output test choose n276 from the list click start test. the regulator should start cycling on and off however if you have an open circuit then it wont work as there is a break somewhere as mentioned
    8P S3
  31. #30
    Dec 2013
    68
    Please dont think im post clocking or anything, i understand that on some forums, an email is sent when a new post is made on a thread.....Id just like to know if the OP got to the bottom of this and how it was fixed? 2 years old, i apologise...
  1. Fuel pressure - S3
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2009, 08:49
  2. S2 Fuel Pipes + Fuel Pressure?
    By oollit in forum S2/RS2 Forum
    Last Post: 31st March 2009, 22:35
  3. Fuel pressure should be
    By Bignick in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2009, 00:35
  4. Fuel Pressure
    By imported_VaulterTim in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2006, 19:04
  5. Fuel pressure
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2005, 21:08
