Badger5EM Tuning
Results 1 to 10 of 10
    swatchuk's Avatar
    Nov 2008
    208
    Confused. Clutch and flywheel advice please
    Bit of advice on which clutch set up to go for please. Just had my S3 put to stage 2+ and the instant I put my foot down it slipped so need a new one now. From what I've read on other posts these are the options I need to decide on.
    Sachs SRE uprated clutch and a dual mass flywheel
    Sachs SRE uprated clutch and Sachs single mass flywheel
    Or Spec stage 2+ or stage 3 clutch and Spec aluminium or Steel single mass flywheel??
    I'm just wondering how bad the noise and gear changes are with the smf? I don't mind a bit of extra noise but don't want to make it really bad as it's my daily car. I do the occasional track day and even more occasional drag at the pod.
    Any advice from you guys who have got any of these set ups would be great. Or if there's anyone in the north west area that wouldn't mind meeting me and showing how there's is would be even better.
    Thanks guys
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Sachs + LUK(oem) Dmf is what i have. Works great with almost OEM feel. No noise either. No experience of the single mass kits but unless your using it all day on a track i would imagine my set up would be fine for you. S3Alex is running ~450BHP on this setup and had no problems thus far.
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by S3RYE View Post
    Slight update on that....!.....the Sachs has been excellent,and has managed well beyond it's manufacturer specs,but Stg4 has finally overcome it.
    It was OK with 440lbs,but is definitely not OK with 2bar boost and an extra fuel pump,and the extra torque will make it slip.....Stage 2+ though will be fine.
    brough74's Avatar
    Oct 2010
    423
    I agree with S3RYE it is what i run aswell, clutch pedal is a bit heavier but fine once your use to it
    S3 gone but not forgotten, now on a Golf R
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    The smell of your burning clutch brough74 lol
    brough74's Avatar
    Oct 2010
    423
    Well it was new when i took you out and had to bed it in lol
    warren_S5's Avatar
    Oct 2007
    7,135
    Think DMF is the safer long term bet. Better drivability, less strain on crank, everyones a winner!
    VAG Junkie
    Dec 2007
    Newbury - Berks
    224
    Got to agree with warren, stay DMF. I think SMF will be hard work/annoying on a daily + the added strain on the crank etc can cause serious issues.
    Current - Ibis White S3 with added LOBA,Sachs,AutoTech,Custom Map,Recaro,ITG,Eibach,3SDM,Milltek flavourings.
    Ex Ibiza Cupra R, Mk1 Leon Cupra R, Mk V Golf GTi, Mk2 Leon Cupra K1 and B7 Audi RS4 Owner!
    swatchuk's Avatar
    Nov 2008
    208
    Thanks for all the advice so far guys. I just want to do the right thing first time as I don't want to be taking the box off again. To be honest my car doesn't get much stick really, i was just concerned that if I ever want to do a drag race will the flywheel give up. I had a single mass in my 8L S3 and it didnt bother me to much but from what I've read things are different in the 8P.
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    Ive gont down the SMF route, and it does make a bit more noise on idle (flywheel chatter) but other than that i love it!
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
  1. clutch and flywheel advice 2.5tdi
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2011, 22:34
  2. Advice Please: Organic Sports Clutch or Single Flywheel Conversion?
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2010, 13:45
  3. Clutch And Flywheel
    By johnnysalv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 20:54
  4. Confused and need advice plz
    By Trick in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 21:36
  5. Clutch/Flywheel help??
    By Matty-YellowS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2010, 20:17
