OEM Varta Battery Sealed or Wet
RS84
R15 - TDI Power
Dublin, Ireland
Need to charge the OEM Varta battery in my 2005 2.0 TDI.
Does anyone know if this is a sealed or wet battery?
Only code I can see on top is VAO, and according to the Varta website that doesn't exist. No indication as to what the type is either.. black dynamic, blue dynamic etc. Its a 72Ah wilth part number 1JO 915 105 AF.
Don't see any valves on top but there is what could be a cover on top. Don't want to try and force it off if it's not meant to come off!
It's a wet lead-acid battery that does not require topping up and consequently cannot be opened.
It is not like the sealed lead-acid battery that is used for golf carts, mobility scooters etc.
Bang it on charge using a normal car battery charger and if it will not hold the charge then it needs to be replaced.
Thanks Fossie.
It's gone from driving across the county twice a day to just sitting in the driveway.
Hopefully it just needs a top-up.
