Sky InsuranceBadger5
    Mar 2010
    Grantham UK
    39
    Uneven Rear Tyre Wear
    My A3 Sportback Sport has got to 16k miles and needs new front tyres, both have worn evenly if not a bit more down the middle suggesting tyre pressure could be a bit lower in future. I am happy with that.
    BUT the rear tyres, I have discovered, have worn badly on the outer edges (1.6mm outer edge 5mm inner edge) which I am extremely unhappy about.
    I have had the tracking checked and all is OK, Mr Audi says this is normal, I am thinking half my rear tyre life has been wasted.
    The car is running on standard factory suspension, wheels etc
    Any thoughts on this problem??
    Sportback, 1.8TFSI, S-tronic, Ibis, Adaptive Xenons, Leather/Alcantara
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    sounds like wheels were not correctly balanced
    steer clear of Audi when the time comes to purchase tyres, find a reputable local fitter
    Feb 2011
    535
    You've had the tracking done, but have you had proper 4 wheel alignment done? Costs anywhere from £50 upwards depending on how far out your wheels are.
    I wouldn't have thought it is the balancing that is at fault as you would be experiencing some vibrations through the floor.
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
  1. Uneven rear nearside tyre wear
    By snottie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 06:05
  2. uneven tyre wear help!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 07:39
  3. Uneven rear tyre wear?
    By leecs3 in forum TT/TT-S/TT-RS Forum
    Last Post: 17th October 2007, 15:37
  4. Uneven Tyre Wear
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2007, 21:43
  5. Uneven Tyre Wear
    By imported_MancheS3er in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2004, 16:08
