Results 1 to 16 of 16
    Dec 2011
    Rear washer leaking into boot on offside.
    Good evening. I have a TDi 170 A3 sportsback with a leak. The rear wash stopped working so i checked the connection in the boot. all fine (previous problem this forum assisted with) The screen wash in coming out of the grill in the boot on the offside above where the wheel would be.
    Any ideas how to access this area so i can check to see if its a split pipe of just popped off. I tried access through light cluster to no avail.
    i dont want to start yanking bits without knowing i'm doing the right thing.
    any help will be appreciated
    Gaz
    thebambam's Avatar
    P.I.M.P
    Dec 2011
    Gutersloh Germany
    65
    Follow thebambam On Twitter
    Have you pulled the roof liner off, where the pipes would be, Then get someone to spray you can usually here it.
    Dec 2011
    I'll give it a go.
    Dec 2011
    Nope,
    Does the pipe run under car, up offside above wheel arch then up to offside boot hinge? I'm guessing it could be leaking anywhere then following pipe to the grill.
    I'll have to try again when it light and not -74c
    I'm guessing removing the roof liner is a dealers job?
    thebambam's Avatar
    P.I.M.P
    Dec 2011
    Gutersloh Germany
    65
    Ive not done it with an audi but my golf had the pipes going through the roof on the passenger side. through the rubber gromet on the boot to the whiper. I just pulled my liner from the door but not right off just enough to see.
    Dec 2011
    Hmmm, I'll phone audi tomorrow re the recall for the injectors so i may get them to have a look before i ruin it all.
    Fossie
    Rhubarb Triangle
    3,961
    There is a pipe joint behind the offside upper boot lining just above the convenience module. Mine froze and popped off last year and was an absolute b*****d to get at and fix ! You have to remove the boot floor and some of the parcel shelf support before you can release the boot liner. Then the problem is that the connector joint, once separated, does not always go back properly and either pops off again or leaks.
    I had to cut the proper connector off and find a way of jointing the two pipes with a different sized pipe and secure it with tie-wraps.
    The leak also knackered the canbus connector to the convenience module which has been on single wire ever since !
    Took me 5 hours in the freezing cold last January to fix !!
    Suggest you leave it to Audi if you can. Good luck !!
    Dec 2011
    I think I will. Thanks for that.
    26,762
    The leak also knackered the canbus connector to the convenience module which has been on single wire ever since!!
    I've got a spare conv module if you want to test that Mike, see if problem goes away, cant recall where we got with that issue tbh, did you scratch the terminals on the wire ends & the conv module?
    Fossie
    Rhubarb Triangle
    3,961
    Sorry for delay in replying but Norovirus got me ! Many thanks for the offer mate but, to be honest, I can't see the point of scrabbling away trying to get the old one out when there appears to be nothing wrong with the car ! I can still make coding changes in the convenience module even though it is only single wire communication. The only sign of anything wrong is a fault code in VCDS.
    Yes, I did scratch the terminals on the connector before reconnecting the wire but not the bit where it goes into the module.
    Thanks again for the offer and Merry Christmas to you all.
    Dec 2011
    Leaking Washer Pipes
    Had the same problem with my 54 A3 ,resulting in failure of boot latch switch causing intermittent alarm activation, Bose system Amplifier failure (£465 Replacement) .rear wiper motor failure.
    Pipe split directly above amp and fluid tracked along boot liner and soaked everything in its path.
    A similar pipe failure happened to my previous car a 98 Golf and also to my sisters 55 Polo
    This will continue to Happen to all VAG cars until they improve the quality of the pipe fittings and pipe section , also you have to question why they continue to run the pipe in a wire harness above electrical components.
    Feb 2012
    16
    Hello,
    Just noticed this post and looks like I have been the subject of a similar problem on my 54 A3, the amp just stopped and after ferreting around the rear drivers quarter found the amp had been soaked and the amp was beyond repair, the whole area around was damp.
    Interested to see if you sorted out the problem and what did you do. As far as I can tell this is the only way that my amp has been destroyed as there are no obvious leaks in the vicinity, great build quality!!
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by steve404 View Post
    Hello,
    The component in the rear drivers quarter is the convenience module, not an amp !
    Feb 2012
    16
    The item I mentioned which has got flooded IS the Bose amp situated behind the panel on the drivers side rear panel by the parcel shelf, or put another way inside the car roughly adjacent to the petrol flap on the outside of my 3dr A3, I had to remove the offside panel in the boot to trace it, also in this area is the seat belt retractor mechanism for the rear offside seat belt. I have pulled the amp out but it has obviously suffered a constant water ingress over time and the inside of the amp is scorched/burnt, trying to source another and obviously sort out the water leak which I am now convinced is the water tubing leading from the front of the car to the rear which feeds the rear wash/wipe and it appears the piping has come adrift at a junction and dripped the water onto my amp causing the problem. Part number I need for the amp is 8P3 035 223.
    Steve
    Fossie
    Rhubarb Triangle
    3,961
    OK mate - sorry - my sportback has the convenience module in that position.
    You don't say what year your car is but the 2006MY version is suffix 'A' and is £456 inc. VAT from Audi !
    Aug 2009
    Stroud
    249
    I have a 2007 Sportback with BOSE installed and want to check the pipe and connectors to the rear wiper just to make sure nothing is leaking as don't fancy replacing the BOSE amp!!
    Can someone please confirm which side of the boot lining I need to remove? What is the best way to go about removing the lining?
    Thanks in advance
  1. Washer fluid leaking away
    By Alibi in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2011, 22:42
  2. Rear washer leaking, front near side...
    By SixDegrees in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2009, 00:09
  3. Offside Inner CV Gaiter leaking?
    By jamies in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2009, 15:11
  4. Back washer not working.....leaking hose in rear quarter???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2008, 19:36
  5. Rear washer leaking at front of car
    By Syzygy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2006, 09:54
