Chris NottMonster Motorsport
    Morells
    what do i need for a revo stage 2+
    hi guys/girls i have a S3 and have a revo stage 1 fitted and the forge DV and the Forge twin air intake system and am going to order the turbo back millteck system after xmas. I know i need the front mounted intercooler and hpfp but was wondering if there was anything else you would recommend for the stage 2+ before i go to revo with it?
    also has anyone got the big brake upgraded AP brakes and what they are like as i want to fit them after the stage 2+
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Quote Originally Posted by Morells View Post
    hi guys/girls i have a S3 and have a revo stage 1 fitted and the forge DV and the Forge twin air intake system and am going to order the turbo back millteck system after xmas. I know i need the front mounted intercooler and hpfp but was wondering if there was anything else you would recommend for the stage 2+ before i go to revo with it?also has anyone got the big brake upgraded AP brakes and what they are like as i want to fit them after the stage 2+
    You've got pretty much all you need there,and I can see you've thought of the brakes as well,which you would need,asthe stock items are a bit prone to fade.
    If you havent sorted the suspension out as well,it's a good time to do so,as the extra power will really accentuate the floppy stuff that comes from the factory....there are a good few brake kits you can use,inc RS4 fronts,VWRacing,APRacing and a few others,and I chose the VWR kit,which works and feels about the same as AP kits I've used before.....plenty of stopping power,nice feel and no fade......hope you have fun with the results.
    Morells
    Quote Originally Posted by S3Alex View Post
    thanks for the advise on the brakes will defo look into all the makes. when you said upgrade the suspension what did you have in mind i was just going to get the H&R Cup suspension kit and H&R anti roll bars but should i uprate the bushes? or get coilovers aswell?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    A decent coilover setup such as kW v3 or Bilstein plus the ARBs will transform the ride.
    Feb 2009
    Aberdeen
    2,491
    BBK, suspension (ARBs at least) and uprate the clutch/flywheel (the final step I need to take, not looking forward to another 4-figure bill just for 'prep work'), then you're good to go.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
  1. REVO - STAGE 2 - STAGE 3 - BUILD SPEC'S - K03 - K04 1.8T
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2011, 18:27
  2. Time for Stage 2 me thinks....REVO Stage 2 Owners Help
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2010, 20:07
  3. Revo Stage 3
    By jsws3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2010, 21:05
  4. From MTM Stage I to REVO Stage II...Oh my god...
    By hatmeow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2008, 12:52
  5. Now have Revo stage 1 for 1.8T !
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2007, 08:44
