Monster MotorsportVolks Autos
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By basssound
Thread: EGR fault and DPF blocked
    Dec 2010
    203
    Well last night the EML come on and then this morning the DPF warning came on.
    I used a scanner and checked the fault codes, there's only one fault.
    P0404 - Exhaust Gas Recirculation circuit range/performance
    Now obviously because of this EGR fault the DPF won't regenerate :/
    Anyone got any information or help, i'm reluctant to spend £200 for the EGR valve if it turns out the blocked DPF could be the cause?
    Fossie
    Rhubarb Triangle
    3,961
    You're sure you have a dpf ? Presumably you have a 170 ?
    Dec 2010
    203
    Yeah it's a 2.0 TDI 170
    Engine code is BMN, i'm a diesel mechanic for merc benz but I do know that a blocked DPF can cause EGR issues and vice versa
    Fossie
    Rhubarb Triangle
    3,961
    If you're a merc mechanic then you will know that VCDS is the usual diagnostic tool for VAG faults. Ross-Tech fault categories do not recognise that code but this may be helpful :- 16787/P0403/001027 - Ross-Tech Wiki
    Dec 2010
    203
    The P0404 is a recognised code for diesel engines with electronic EGR valves, I must admit I did use a MAC tools scanner
    but i'll have access to VCDS on Monday. I keep meaning to buy VCDS but I never seem to get round to doing it.
    Dec 2010
    203
    Anyone got the Audi instructions for checking the EGR feed, earth and reference signals?
    Dec 2010
    203
    I have removed the EGR valve and stripped it down to find the actual trumpet has snapped off the adjuster fork.
    A picture in a bit will show what I mean but this does mean I need a new EGR valve
    Stampie likes this.
    Dec 2010
    203
    Here is a picture of the mechanism inside the black plastic housing, as you can see the 'T' bar has snapped off, the round disc is the top hat.
    I have removed the disc and welded the 'T' bar back onto the trumpet which controls the amount of exhaust gas allowed through.
    Jan 2012
    SW London
    751
    not thread hijacking but i have a weird problem with the dpf not regenerating, whereabouts are u based?
  1. Allard 'Powerpipe' EGR delete kit Vs EGR blanking plates?
    By BudgieV8 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2011, 19:52
  2. EGR Fault
    By chris87 in forum General Chat
    Last Post: 28th July 2011, 05:21
  3. EGR Fault
    By chris87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2011, 00:31
  4. EGR Fault
    By chris87 in forum General Technical / How To
    Last Post: 27th July 2011, 18:39
  5. 2.0tdi egr valve fault and less MPG!
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2010, 13:55
