Volks AutosBadger5
Results 1 to 38 of 38
Like Tree7Likes
  • 1 Post By warren_S5
  • 1 Post By crunchie
  • 1 Post By RedDejavu
  • 1 Post By bez101
  • 1 Post By bez101
  • 1 Post By S3RYE
  • 1 Post By PaulAr
Thread: S3 is not starting!!
    Dec 2011
    22
    Hi Audi-sport.net
    I'm new in here and need some help.
    My car is not starting. When I turn the key it starts to *bib* and the DIS says BRAKES !
    The keys didnt work suddenly, but now they work fine as they should, but the car does not start.
    Checked the brakes and everything seems to be as it should.
    The steering-column lock was recently changed and the battery has been a little low.
    Any Idea's what it might be?
    warren_S5's Avatar
    Oct 2007
    7,166
    Nice mix of issues there any of which could have a hand in your problem. Can't imagine there is a safety feature built in that stops car being driven if brakes are worn, unless it's a much bigger brake issue (e.g. ABS failure).
    Battery low will not help as these cars have a lot of electrics to manage. I think it has a smart system which shuts down unnecessary ancillaries to allow car to start with remaining available power, but if this threshold is passed it may be a no go.
    First port of call try charging the battery (cheapest option) - if no charger get a jump start.
    Then if not working get the steering column checked.
    When you say the keys didn't work but then they did, are you sure this wasn't the battery causing this issue?
    And do yourself a favour mate, do get the brakes checked, especially at this time of year when it's hard enough to brake. Pads can be had from £80+ if you self fit so don't risk your safety, or others.
    Best of luck getting it sorted, but remember cold weather seriously impacts battery life / performance, and if its the original battery and the car is in the 56-57 age range it may be getting in that age range where it needs replacing, so GSF or ECP should be able to source one for reasonable money.
    vijays786 likes this.
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    It may not let you start it if you brake fluid level is low or a fault in the level sensor?
    Just a thought.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,484
    get someone to come round and plug VAG in to see what errors you actually get.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    brakes even abs fault wont stop the car starting
    the brake symbol does come on with low battery
    so as above recharge or jump start the car
    Dec 2011
    22
    Battery does not seem to be the problem. I've charged the battery and still it does the same thing.
    Could it be something to do with car has been decoded some how.
    Key is working fine and open and closes the car as it should.
    On the DIS it says ((!))
    Brakes
    The time and date on the car seem to be wrong aswell.
    Jun 2010
    Coventry/Warwickshire
    2,074
    Buy a new battery
    bez101's Avatar
    Jul 2008
    8,530
    try to put a jump pack or jump from another car
    so many ppl get the brake in red and 3 beeps
    sometimes batt seems fine but its just not got enough juice to run all the moduals and start it
    also with the time and date wrong points to dead batt
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    i had a flat battery recently and the exact same warnings came up. not much help but i havent changed the battery and all seems fine.
    (btw, i charged the battery with jump leads and all is fine since)
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Dec 2011
    22
    Dont understand guys coz there is a prof. charger on the car at a workshop. And battery should be fully charged how can it make a difference if i connect jump leads? i'm pretty sure it has something to do with coding the as the steering-column lock was changed or am i totally wrong? The guy at the workshop couldnt get a reponse on the car when he plugged it to a computer.
    :-S Audi has a long waitng before they can look at the car.
    Dec 2011
    Im was having a similar problem turns out water has got into ecu and fried it! because its located under wiper scuttle,
    What years is yours and have you had it mapped?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    Quote Originally Posted by vijays786 View Post
    Brakes
    car being decoded? are those keys new? as in are they cut new?
    just thinking if the keys are not programmed to the immobiliser then the engine wont start! also you are pressing down on the clutch before turning the key right? (manual cars only)
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Dec 2011
    22
    What! you must be kidding me.. That sounds really expensive.... how much is a ECU?
    bez101's Avatar
    Jul 2008
    8,530
    right so u had some work done on the car ?
    did it start b4 the car went into the garage ?
    did it start after the steering lock was changed ?
    bez101's Avatar
    Jul 2008
    8,530
    water in the ecu box can do the relays
    check in there as above relays dont cost much
    Dec 2011
    22
    Quote Originally Posted by itwasntme187 View Post
    The key is original and works as it should. The immobilliser is located on the steering-column lock and this might be coded wrong or something And yes i'm pressing the clucth.. hehe had the car for some while now so i know i'm suppose to.
    bez101's Avatar
    Jul 2008
    8,530
    i think you should start from the begining
    did it run after steering lock was changed ?
    the immoblizer is coded to the clocks not the steering if codeing was lost car would start for 2 seconds cut out and a yellow light would flash
    Dec 2011
    22
    From the Start:
    The car is a s3 from 2007 and yes it is mapped.
    Some while back someone broke in to the car and had put a screwdriver into doorlock and broken it.
    The sat nav was stolen and for now i've put the orig. audi chorus in. They also tried to do something to the keyignition but didnt suceed, and the key goes in like it should. Allthough some how the steering-cloumn lock jammed/stuck.
    Bringing me to my problem.
    The car has been standing still for a month now.
    So now the steering-column lock has been changed and it does not start.
    Hopes this helps and sorry for the lack of infomation. i'm new in here.
    bez101's Avatar
    Jul 2008
    8,530
    right if it was the immo the car would start for 2/3 seconds and cut out if it dont do this then rule that out
    check in the ecu box for water if so dry out etc replace relays
    becos the vcds wont connect id say ecu box
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Is this DSG ????
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    not really, my dads merc just clicks if the immo is not there, we tried it with a new key that opens the locks and works on the remote but no engine
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    bez101's Avatar
    Jul 2008
    8,530
    not been funny but this aint no merc
    audis with an immo problem fire up for 2 to 3 seconds then cut out
    there to very diffrent cars
    Dec 2011
    22
    It could.. be i'm not so sure about the relays havent checked yet.
    I will try to check it and then tell you, but how could water suddenly go in to the ECU??
    Thanks for the replys so far. Really appreciate all the help for now.
    If anyone else have experienced a problem like this be welcome to write.
    The car is not DSG, it's manual.
    Dec 2011
    22
    Can someone post picture a picture of of their box with the relays look like?? Just want to check if everything is were it should be.
    bez101's Avatar
    Jul 2008
    8,530
    take a pic of yours and ill tell you if its ok
    i cant be arsd to open mine if its not wet tho it should be ok
  28. #27
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Did you check the spark plugs?
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  29. #28
    Lewis583's Avatar
    Mar 2010
    872
    Is the engine not turning over or not firing?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  30. #29
    Dec 2011
    22
    The computer that the work shop (wow) have Cant even communicate with the car and cant roll the windows down with the Keys.
    The battery has a charger on from cebora..
  31. #30
    Dec 2011
    22
    Nothing happens when i turn the key.. Engine does not turn nor fire. The only thing that happens is three bibs and it say brakes like in the first photo.
  32. #31
    bez101's Avatar
    Jul 2008
    8,530
    does the fuel pupm prime can you hear it ?
    when you turn key does it click or anything
    where are you based ?
  33. #32
    Lewis583's Avatar
    Mar 2010
    872
    I'm guessing the chap is overseas judging by the left hand drive and kmph speedo?
    Can they not get communications with any ecu on the car or just the engine control unit?
    If it's just the engine control they can't get into then they should be checking the earths and feeds to the engine control unit.
    Full VCDS
  34. #33
    Dec 2011
    22
    Nothing happens no Clicking Sound or anything. Could te reason be that the coolerent fluid is under minimum, the Oil is under minimum and the fuel is almost emty. Could it be at safety precaution Then ? Have to mention All the details even the smallest .
    I'm based in sweden.
    Thanks guys
  35. #34
    bez101's Avatar
    Jul 2008
    8,530
    no nothing to do with fuel oil etc
    to be honest id find a better show and get someone that knows what there doing to look at it
  36. #35
    Dec 2011
    22
    Yes i know but they have a long waiting at Audi. Have booked a time though.
    Was All the electric components in the right place on the photo?? Fuse relays ect.
  37. #36
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,049
    Mine did this, same problem, same warning lights.
    It started with the car cutting out when stuck in traffic, displaying the same warning beep tone and DIS `brakes` sign.
    AUDI assist came out and it continued to happen intermittently, starting then cutting out etc..
    It went into the dealer (under warranty) and the dealer showed me it hooked up to diagnostics and cutting out, when it did, ALL of the Control Modules went to FAIL on the diagnostics machine, which was highly unlikely.
    So the dealer pulled the car to bits, testing every module, only to find it was a power supply RELAY that sat in the circuit ahead of the Control Modules.
    Basically, when the relay shat itself, all of the Control Mdules went down, and the BRAKES warning turned out to be a spurious DIS fault which turned out to be a bit of a red herring and possibly casued by a module associated with the brakes sending duff signals.
    Anyhoo, I am pretty sure this is your problem.
    Just a shame I cant tell you which relay it was, although it turned out to be just a couple of quid for the part and an easy job!
    Good luck with the fix but I would concentrate your efforts here.
    PM me if you want more info or help.
    Paul
    EDIT: Original Post here, sound familiar? S3 Cutting out Oh Oh..
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
  38. #37
    Dec 2011
    22
    Poul!!!!!!!!!
    You are a darling!!!! Problem solved! It was the relay!!!
    Now the car is running, but it seems like thère is somethings wrong .
    The car is shaking and it doesnt have any power.
    I connected the computer and it says fuel pressure regulator 2 fail.
    And the EDC and Engine lights up in DIS.
    Want to thank you guys very much. I'm a very happy that people are so friendly and helpful in here!!!
  39. #38
    Nov 2013
    90
    Which relay did this turn out to be? I have starting problem my S3 will turn over fine but just will not fire up, anyone have any ideas on my problem, I've been searching for ages
    Sorry for pulling an old thread back to life
  1. S3 not starting??? Help please....
    By Lacey123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2009, 22:44
  2. S3 nearly not starting - help please?
    By dgannon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2008, 01:38
  3. S3 nearly not starting - help please?
    By dgannon in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2008, 16:07
  4. S3 Starting problems
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2007, 21:51
  5. starting? help some one must know!
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2006, 12:03
