Volks AutosSky Insurance
    Living a little!
    London
    181
    Exclamation RNS-E - No Power Problem - HELP!!
    Hi All,
    I had a problem with no radio so removed RNS-E and checked connections. It was a loose connection. Sorted! Now I have radio back.
    Then... Im not sure what happened next when putting all back together. It tuned off. I looked at the screen and the bottom part of the screen there were fine grey lines running horizontally then they faded and now completely blank.
    I have checked fuses on side of dash and under bonnet and can't seem to find one blown. I have checked 15amp in actual RNS-E and all fine and held down on/off button for 30secs.
    I have a 6CD changer and that also is not powering up. I have no buttons eliminating on RNS-E or 6 CD changer when headlights are put on.
    Anyone know what this could be and how to resolve?
    Living a little!
    London
    181
    Anyone?
    27,094
    Patients is a virtue, you only posted 8 hours ago & it is friday & its xmas.
    Its got to be a power issue if you arent getting anything, so check your fuses again, assume you've stuck them on a multimeter or the like to test continuity?
    Have you tested the power wires coming into the quadlock for voltage?
    Have you got a quadlock adapter you can stick 12v to & plug into the rns-e, as they do power up away from the car if need be.
  1. help please RNS-E problem
    By carlito71 in forum In-Car Entertainment
    Last Post: 16th July 2011, 20:59
  2. RNS-E Problem
    By s3ilver in forum Satellite Navigation
    Last Post: 10th October 2010, 09:57
  3. RNS-D Noise on Power Off
    By biyitch in forum Satellite Navigation
    Last Post: 28th April 2010, 23:16
  4. RNS -E Problem
    By Leetaylor in forum In-Car Entertainment
    Last Post: 9th July 2006, 20:22
  5. RNS-E problem
    By cclarke184 in forum In-Car Entertainment
    Last Post: 17th July 2005, 00:05
