Badger5Sky Insurance
    Dec 2011
    Leicester
    21
    How to flush the coolant (55 Reg Audi A3, 2.0tdi)
    Hi all,
    How can I flush the coolant (almost water) from my audi? the level drops every week, the car had a major service from audi but nothing wrong and was advised to replace the coolant since it was too weak.
    cheers
    sando's Avatar
    Sep 2011
    58
    never heard of that before mate, from what I understand the coolant is closed and works under pressure. Should only notice a drop in level if there is too much in and the system has overflowed as a result.
    I found that I had a coolant leak not long ago, was only losing a small amount, but enough for the warning light to eventually come on.
    After some research found that a common result the failure of a seal and an O ring in the Y connector (not to sure where this is) Instead I ended up using K seal, which fixed the problem as the leak was only small and is alright to stay in your coolant system.
    27,013
    With all respect, if its dropping weekly, then either you have a leak on piping, rad, egr cooler or the infamous porous head, the viscosity shouldnt matter as its a sealed system as such, so I would do some more research/testing with an independent with the tools to find out whats going on, if audi are telling you otherwise.
  1. coolant flush/change
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2011, 14:19
  2. coolant flush
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th December 2010, 09:08
  3. S3 Coolant Flush
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 13:11
  4. engine flush in 2.0tdi
    By vw754 in forum Diesel forum
    Last Post: 11th January 2009, 18:54
  5. AUDI A6 2.0TDI SE 54 REG AIR CON PROBS
    By KJN in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th May 2008, 17:11
