Sky InsuranceVolks Autos
Results 1 to 10 of 10
    Sep 2011
    26
    Arm rest squeak?
    Anyone elses center arm rest noisy? Mine squeaks loads when i go over small bumps etc or move my arm slightly to change gear. Its just a general squeak from the whole thing moving within the center console, so not sure there is a lot that can be done, but does anyone have any ideas?
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    remove the rear ashtray and check if the bolt is tight for the armrest
    Full leather/19"wheels/cruise/
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    yeah i get the irritating squeak!!! was going to post so interested in any ideas for a fix. i don't think the bolts, for me its plastic squeak when i rest my arm is on the arm rest. so.. any ideas to get rid would be great
    Oct 2010
    92
    Mine used to squeak as it rubbed against the plastic backing of the drivers seat. I just bought some sticky back felt and attached it to the side of the armrest, no more squeak!
    Sep 2011
    26
    Just been having a look at it, dont think its possible to stop it. Whatever angle i move, touch or poke the rest from, it squeaks. Its just the way all the bits of plastic fit together, its not actually rubbing against anything. Annoying, as its such a good feature and i wouldnt be without it.
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    If it were me I'd using a small amount of WD40
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    wd40 it be
    Aug 2011
    104
    use WD40... it worked on mine....
    Feb 2011
    534
    Quote Originally Posted by sum-audi View Post
    Where did you apply the WD40?
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    Jun 2011
    52
    Know it sounds silly but I moved my seat 1 click and it stopped the squeaking for me
  1. A3 arm rest?
    By tombayley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2009, 19:46
  2. A3 arm rest same as an A4 cab arm rest??
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2009, 09:56
  3. arm rest
    By martyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th May 2009, 20:00
  4. Arm rest
    By S3 SAF in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2008, 20:37
  5. Arm rest - again
    By Lenaldo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2006, 15:49
