Sky InsuranceAH Fabrications
Results 1 to 15 of 15
Thread: Wheel problem
    Dec 2004
    Belgium
    Wheel problem
    Hi, I had new 8 x 19" A8 wheels ( 225x35x19 ) installed yesterday, but the problem is that the one's in the rear really hit my rear bodywork when I take a bump... They stick out too far I think, what can we do to make it ok again... The guys from the shop where I got them want to "drill" out some space where they are attached so they can put them deeper...
    Anyone had the same problem???
    http://koen-dries.magix.net/
    see at the pics at hobby
    Jan 2005
    London
    70
    Re: Wheel problem
    what offset do these wheels have?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Re: Wheel problem
    Sounds like an offset problem, your car requires wheels to have offsets of round ET45, but the 8 x 19" A8 wheels probably only come in ET35. It is possible to machine some of the metal away from the hub side of the wheel to bring it nearer the required offset, but wouldn't that weaken the strength of the wheel? [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Dec 2004
    Belgium
    Re: Wheel problem
    I have absolutely no idea...
    Jan 2005
    London
    70
    Re: Wheel problem
    it was mentioned in another thread that the standard audi wheels offset for the 8P is 56.
    I'm looking at installing 35 offset wheels, but if they'll rub at the rear, maybe not once the car is lowered.
    Dec 2004
    Belgium
    Re: Wheel problem
    Does adjusting the springs help?
    Jan 2005
    London
    70
    Re: Wheel problem
    sorry koen - that was a bit confusing. I meant that I might not fit wheels with a offset of 35 once the car is lowered, if you're having problems now. what suspension do you have?
    Dec 2004
    Belgium
    Re: Wheel problem
    The sports suspension, minus 1.5cm...
    Jan 2005
    London
    70
    Re: Wheel problem
    so is that sports shocks with aftermarket springs?
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Re: Wheel problem
    Whats the offset of the wheel now and how much are they planning on shaving off!
    It is possible to machine the inner wheel faces to change the offset...
    Dec 2004
    Belgium
    Re: Wheel problem
    On the phone they said the could machine off 3-4mm
    ANd no, I didn't change anything too the shocks yet...
    Mar 2003
    UK
    426
    Re: Wheel problem
    I thought going to ET35 would be too much for the A3. Looking at my standard wheels at the weekend, even 10mm further out would put the rim of the wheel very close to being inline with the wheelarch edge. So putting on a 8inch wheel with ET35 is moving the wheel 26mm further out from standard. It is pushing the limits.
    Would you need to change the bolts if you shaved 3-4mm off the wheel? Could be OK, but I would't like to chance it. Any implications on your insurance? If a wheel sheers off and they find out that your wheels had been doctored?
    Jan 2005
    London
    70
    Re: Wheel problem
    is it a problem having the rim in line with the wheel arch? will a stiffer suspension set up help much?
    Dec 2004
    Belgium
    Re: Wheel problem
    I've had some good news a few minutes ago, they ordered the rong ET value it was 35 instead of the 45 I needed, they are going to deliver the right ones tomorrow morning so by 14.00 they should be back on my baby...
    I hope they fit right this time.
    Next is lowering springs, what kind of make is good? I was thinking abt or eibach
    Mar 2003
    UK
    426
    Re: Wheel problem
    Standard is ET56 for the A3. Aftermarket is usually 35 or 45. I personally think an 8 inch ET45 looks best and is still practical.
    Eibach is highly rated. So is H&R.
