Volks AutosAH Fabrications
Results 1 to 14 of 14
    HIGGINS's Avatar
    Mar 2010
    520
    3.0tdi turbo on 2.0tdi
    Ive been looking at the GTB2260VK turbocharger which has been converted to use a vacuum actuator. It also comes with the intercooler 2.5" outlets.
    Is this a good upgrade? Has anyone done it?
    Selling MY11 rear lights, message me for a price
    HIGGINS's Avatar
    Mar 2010
    520
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    no idear would it not have huge lag?
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    HIGGINS's Avatar
    Mar 2010
    520
    not if its mapped correctly
    Sep 2010
    392
    Wouldn't the internals have to be changed because of higher pressure?
    Picked up on the 30th May!
    2013 '13' Plate - Audi TT 1.8 TFSI S Line Roadster | Ibis White | Xenon Headlights with LED DRL | Half Leather/Suede with Silver Stitching | Brushed Aluminium Trim
    Gone but won't be forgotten! 2011 '11' Plate - Audi A3 1.4 TFSI S Line | Ibis White | Privacy Glass | iPod Dock | Xenon Headlights with LED DRL | Half Leather with Silver Stitching | Brushed Aluminium Trim | S3 Pedals
    HIGGINS's Avatar
    Mar 2010
    520
    only thing im thinking of is a mani, 3" down pipe, clutch and map
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    634
    A few boys are running this turbo on the 1.9 ARL's with a custom manifold IIRC.
    HIGGINS's Avatar
    Mar 2010
    520
    got any links or anything buddy?
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    634
    Aug 2011
    242
    What are you trying to achieve?
    There are some very decent turbo options available that are designde to go straight in without adaption.
    Am not sure exactly what the point is when there's a plethora of decent hybrids available that can flow as much air as the stock engine can handle without producing any extra lag. What more could you want, apart from perhaps a lower price tag?
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    Hi there,
    it depends on your power goals, if you want to go beyound 250hp you should user a GTB2260VK don't be fouled that it's a GT22 it has the 3rd gen vanes so the spool would be more than decent of a 2.0 tdi. For a daily driver i would use a GTB2056VK that at 2000rpm can do 1.3 bars or even better if you wannt to limit to 230-240bhp go for a GTB1756VK and your lag will be almost 0, much better response than the stock turbo that is a 1st generation VNT
    LE: you don;t need to change the stock Intercooler that is the same as the GTI has. If you want to be 100% safe you can buy some bosio uprated injectors to protect the cylinder head that is prone to leak coolant.
    Jun 2011
    125
    Quote Originally Posted by shiggins92 View Post
    is this the kit your talking about? GTB2260VK Turbo Kit for VAG 2.0 TDI BKD Engines - FR&R Tuning| ECU Remapping| Stage 1, 2 & 3 Engine Performance Upgrades - (Powered by CubeCart)
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    The above kit isn`t manufactured by or have anything to do with Fr+R tuning as stated on their web site, they just sale the kit. The kit was developed by Ryan at Darkside Developments.Darkside GTB Turbo Kit for 2.0 16V TDI (BKD) - Darkside Developments
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    micasb's Avatar
    Mar 2010
    310
    A3 2.0 with the changes you mentioned
    A3 VR by MB POWER vs. IBIZA ET by Black Demon Files - YouTube
    A3 VR by MB POWER vs. GOLF XJ by AM MOTORSPORT - YouTube
    Cheers.
  1. New car choices: ??? v 3.0TDI v 3.0TDI v 3.0TDI?!?!?
    By BahnStormer77 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2011, 22:38
  2. NOOB! 2.0TDI turbo.....
    By peircey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2011, 22:56
  3. A6 S-Line Le Mans 2.0TDi versus A6 S-Live Special Edition 2.0TDi
    By WagsbyUK in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th February 2011, 19:45
  4. IS A 3.0TDI INTERCOOLER BIGGER THEN A 2.5TDI ONE AND IS THE 3.0TDI TURBO BIGGER
    By johnswales in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2010, 23:40
  5. A3 2.0tdi noise from turbo
    By scobs in forum Diesel forum
    Last Post: 21st May 2009, 19:41
