EM TuningVolks Autos
Results 1 to 8 of 8
    Aug 2011
    24
    Red face Egr Delete Help.... Thankyouuuu
    Not posted much on here since my new turbo being fitted... oh and me dinting my boot lol
    Still loving the car and its goin in for a uprated clutch from larkspeed sometime this week as its started to slip with the map etc...
    Just wondering if anyone can help my identify wether this is the correct EGR Delete for my car,
    VAG 2.0 TDI EGR Roadsport Delete kit - FR&R Tuning| ECU Remapping| Stage 1, 2 & 3 Engine Performance Upgrades - (Powered by CubeCart)
    Its a A3 2004 2.0TDI, I think this looks about right because the other one fr tuning have i think is for the older models of VAG like the Mk4 golfs and older audis with the larger EGR
    Your help would be appreciated, Thanks alot... Scholey
    And next bit to be added .... Decat :D
    chris1988brown's Avatar
    middlesbrough
    578
    yes mate thats the one will go stright on, the other one will also fit but the other one removes the electronic side of the egr also
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    Aug 2011
    24
    Quote Originally Posted by chris1988brown View Post
    Ahh and that will give me a daft warning light all time? lool
    May 2009
    West Yorkshire
    1,609
    Can you fit this to a car that is not remapped? If you can will it bring up any errors or warning lights?
    Audi A3 2.0L TDI S-Line Sportback
    middlesbrough
    578
    i believe both bring up warning light and require turning off via a map, unsure if they can be removed via vagcom
    MY PROGRESS THREAD
    May 2009
    West Yorkshire
    1,609
    OK mate thanks for the info.
    tdi-man's Avatar
    Jul 2009
    1,588
    WASTE OF MONEY . just fit a blanking plate between egr valve and pipe and turn egr of in map job done .
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    May 2009
    West Yorkshire
    1,609
    Quote Originally Posted by tdi-man View Post
    I did this on my old Astra CDTI, it didn't bring an engine light on but going from Chris Brown's reply it will on the A3 whether it's blanked off or totally deleted.
  1. Egr delete
    By chris1988brown in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th October 2011, 15:48
  2. EGR DELETE
    By tonya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2011, 11:27
  3. Egr delete ?
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2011, 16:12
  4. EGR Delete - Which One???
    By MarkTweedley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2010, 17:00
  5. EGR Delete?
    By waqi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2010, 00:10
Tags for this Thread
