EM TuningAH Fabrications
Results 1 to 28 of 28
Like Tree1Likes
  • 1 Post By Ash187
Thread: Follow me home lights on a new A3 without autolights ~ solved
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Follow Helifella On Twitter
    Well after a lot of head scratching - both mine & Trups we ran out of ideas of how to activate this function.
    Trups had done the coding but as the layout has changed beneath the dash we didn't know where to put the repair wire.
    I believe Wes was on the phone saying he didn't think a wire was needed.
    Anyhoo, after giving my car its first ever wax I also dusted the interior (not that it needed it being less than 2 weeks old) but I knocked the high beam stalk.
    Not thinking anymore of it I decided i'd put the upgraded bulbs in the fogs to match them closer to the xenons and noticed the fogs and LED sides were lit...
    Mystery solved.
    Like my Volvo V50 I chopped in for the Audi, to activate the follow me home lights, flash the headlight stalk, lock and walk away in a flood lit path to your front door.
    Obviously you need the coding for the feature to appear in the DIS, but once done, no wire is needed.
    NB: As yet I haven't managed to activate the lights when I unlock the car - maybe this does require the repair wire??
    UPDATE: just been informed if you install the repair wire the above & approach lights will activate everytime, day or night without flicking the stalk etc.
    RegardsHeliFellaVCDS newbie.8V now ordered...I.A.M. Member http://www.iam.org.uk/about-us/ '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates, gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    say what ? i want it doing
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    Definately on an 08 plate the wire is not needed as I have done three in this year now, good to know you've got part of it working, now just to work out if the wire method will work and where to put it on the new layout??
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    Dec 2010
    203
    So what do you need to do on an 07 to activate the locking and unlocking walk away lights?
    May 2009
    West Yorkshire
    1,628
    ^^ Repair wire and then coding.
    Audi A3 2.0L TDI S-Line Sportback
    Sep 2011
    9
    HeliFella, Thanks for the update, however I'm still not sure were the repair wire is fitted. Are you abel to advise for a 2011 A3?
    Regards
    Samboii
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    i dont think a repair wire is needed to activate it as its all there on the DIS. iirc you dont even need VCDS to code it anymore.
    if however someone wants to go down the route of finding out if a repair wire is needed then on the newer facelift cars the pin you need is plug C pin 18.
    MrWhItEwOlF likes this.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    May 2009
    West Yorkshire
    1,628
    Quote Originally Posted by itwasntme187 View Post
    Was needed on my 56 plate A3.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    the comment was made on the newer facelift cars... 2010 -
    the older cars needed it... i think it changed over in about 2008
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Sep 2011
    9
    I think that the activation is only possible if you have "Auto" Lights. Are you suggesting that with the aid of the VCDS i can activate this function to appear in the menu settings of the DIS?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    I am sure i have seen several cars after 2008 that already have the option to switch on the CH/LH lights on the DIS. whether or not this will actually activate it i honestly cannot remember.
    in my car i used the wire and VCDS coding to activate it and yes it would come on in the daytime but it still looked good with the xenons. also bare in mine i have a 2005 A3... but since i have retrofitted the Auto lights pack and properly wired in the ch/lh button from the auto light switch so it works properly and only comes on at night.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Just to clarify, I don't have auto lights, but do have the DIS. When the car was delivered the other week the only option in the DIS lights menu was "interior lights", where I can choose the dimmer setting for the footwell lights (interior light package).
    After Trups connected it to VCDS he enabled the "exterior lights" sub menu within the "Lights" menu.
    Clicking into this menu gives two options
    Coming home lights ~ where you can adjust the time the lights stay on for 0-60sec in 5 sec increments
    Leaving home lights ~ which is just a tick box option.
    So by turning the engine off, flash the headlight stalk, get out and the sides & front fogs stay on for the chosen time.
    I also noted that the green sidelight symbol is lit up on the light switch once the stalk is flicked (even if the switch is left at off or DRL)
    I got in touch with Avus last night and he said to activate the Leaving home lights (illumination upon unlock) I would need the repair wire.
    By fitting the repair wire will always automatically illuminate the lights when leaving the car and unlocking the car regardless of the time of day, without the need to flick the stalk, making this a passive mod.
    All this is based on my car which is a 2 week old A3 Black Edition Sportback with the Xenons & LED DRL's / sidelights.
    May 2009
    West Yorkshire
    1,628
    I see mate, i'll get my coat!
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Tried this on my MY10 TTRS as really wanted this function but doesn't work!
    Coded it and got the options via dis but lights won't activate after flashing the main beam?!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    448
    I'm sure I read on here somewhere that you don't have to permanently connect the repair wire, you only have to earth it once to the relevant plug/socket?
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    slade777's Avatar
    Sep 2010
    763
    Quote Originally Posted by JamS3 View Post
    Same on MY10 A3!!!
    Current:
    A3 Black Edition 2.0 TDI 140
    Jun 2011
    Wellingborough
    1,173
    Hi Guys,
    like helifella said, it wont work with just the VCDS, i opened up the bottom of the fuse box and it looks completly differant to lets say an 08 car.
    Ash, if you ccan get someone local down your way to do the wire then i think you may be able to crack it.
    and here is the link for you guys with the pre facelift cars - cominghomelights - Audi Retrofit
    Trups
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Apparently the wiring blocks are different on the TT to the facelift a3's?
    51
    Hi, i have a 2010 A3 BE and really want this on my car. I have located the wire that needs to be installed (T52C brown plug pin 18), however which control units have to be coded? the dash cluster and the onboard power supply? as i can't seem to find any options to code this? Any help much appreciated, thanks Dave
    Jun 2011
    Wellingborough
    1,173
    it will be in 09CE and you need to activate coming home and leaving home lights then the options will apear on your DIS
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Well I spent the morning on Avus Sportback's driveway trying to sus this mod out, sadly with no joy despite his best efforts & coffee
    This man is a top bloke.
    We've left it with the repair wire plugged into C18 and just coiled up so I can have another go (hopefully tomorrow). We had it earthed and no joy. We're also not quite sure which items to have enabled in VCDS as the obvious doesn't seem to have worked. I am gonna dab the wire to earth and see if that would trigger it (due to what we did today)
    Its currently set on manual over auto which I think is how the headlight stalk triggers FMHL. But there are a few other codes linked to the CH & FMH lights which we're not entirely sure about. My VCDS options are different to Avus' 2009 car just to add confusion.
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Also found this...
    Audi A3/S3 & A3 Cabriolet (8P/FM) Tweaks - Ross-Tech Wiki Ross Tech are the makers of VCDS.
    I remain undeterred
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Does anyone know if the ignition needs to be on when I earth the c18 pin? And is it a simple dab then insulate or to be bolted down?
    Aug 2011
    104
    Even i tried on MY08 with repair wire, which has CE module ending with J and I been told it wouldnot work because of basic module... Anybody confirm pls?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Helifella View Post
    Why don't you just try it ? You can't do any harm.
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Wasn't sure if it would arc or do any harm if I did it with ignition on?
  28. #27
    Spin140's Avatar
    Mar 2005
    Derbyshire, England
    2,013
    Watching this thread with interest, yet another item that really should be standard on cars at this cost level
    I'd really like this function on mine especially during the depths of winter.
    Wife - 12 BMW 320D 181 bhp, 8 Speed Auto, Melbourne Red, Heated Leather, privacy.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy. (Sold)
    Golf GTi MK6 - Revo stage 2, ITG, Milltek Race TBE, AP Racing 4 pot BBK - Sold.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy,Nav, Park sensors, 6 disc, Revo Stage 1, ITG Enclosed Intake - Sold
    BMW M135i F20 - Bloody good straight from the box !
    "Fast Cars are Safer...."
  29. #28
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    366
    Well just been out to dab the wire to earth and no joy. Not sure how we left the VCDS when I went to see Avus Sportback.
    I can still flick the stalk for coming home but nothing when locking or unlocking.
  1. Coming Home & Leaving Home Lights Enabled
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1 Day Ago, 13:54
  2. Follow me home headlights.
    By deanosabby in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th October 2011, 17:44
  3. Coming home and Leaving home lights - VCDS trouble
    By Pricy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2011, 10:07
  4. Follow Me Home
    By LandSpeed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2011, 17:42
  5. Vag Com Faults after Coming Home & Leaving Home Lights Enabled .
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2010, 14:45
