No bowfer your wrong. I had a manual TDI for a day and hated it for one reason alone - the amount of times I had to push the clutch down to change gear because of the short rev range, having always had petrol engines up to then. I then had a TDI with a DSG for a day and it was marvellous. Some months earlier I had a drive in an TDI A4 with the multi-tronic gearbox and liked the way that would look after the 1st and 2nd changes that come up quickly with a diesel when you pull away quickly say from a junction. The DSG behaved in the same way and it was just what I liked.
During my normal driving I use tip-tronic all the time unless I'm creeping in a traffic jam when I switch to D. In tip-tronic I nearly always let the DSG handle the changes from 1-2 and 2-3 when it reaches max revs in the lower gear. After that I normally do all the up and down changes myself using the lever or paddles except of course the change to 1st whenever I stop.
So I was well aware of exactly how the DSG would behave and it was that behaviour that convinced me to change to a diesel from my 4 previous manual A3 1.8T Sports.
I can see you point about the DSG not holding the max revs, but I personally would hate it if it did, unless of course it was driver selectable. That, of course, would give us both what we want. Perhaps one day...
