Sky InsuranceVolks Autos
Results 1 to 22 of 22
    Sep 2011
    9
    Audi A3 Black Edition Jan 2011
    I would like to activate the coming home/leaving home lights on my car. I have no auto light switch. I think, having read many posts on here, that i can alter the computer settings to enable this function (i do know that this will mean the lights will be on during the day as well). Can anyone advise me where in the computer, i can find the settings that need to be altered and more importantly what i need to type to make the car do this? Many thanks
    Aug 2011
    North
    19
    Hi there,
    If you navigate thru the Drivers information system via the switch on the right stalk, you will find the option to check/uncheck the lights options, the coming/leaving home function is located within that menu.
    If your vehilce does not have this function i'm sure your Audi dealer will tech the car to set the function for you.
    Hope this helps.
    A3 1.8TFSI Sportback - Black Edition.Ibis White.Pan Roof.S3 pedals.........Lovin it!!!!!
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    may sound daft but what does this function do ?
    Dec 2010
    Littleborough
    104
    Follow this link, cominghomelights - Audi Retrofit
    I have the same car as you and did the mod a couple of weeks ago, the mod does not mean your lights will be on during the day, only on when you lock / unlock the car for your predetermined time.
    You will need VCDS to enable the function.
    PS - only check Byte 00 Bit 07 and not 05 as well.
    Dec 2010
    Littleborough
    104
    Quote Originally Posted by bloblob2 View Post
    When you unlock the car the headlight come on, (suppose its incase you live in a dark unlit area?) light also stay on after you lock the car.
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    my interior lights come on, should the headlights come on as well then? i to don't have auto lighting
    Dec 2010
    Littleborough
    104
    Then you also need to carry out the mod, really simple and quick to do.
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    looked at the mod, looks simple enough but i don't have access to VCDS
    Dec 2010
    Littleborough
    104
    Someone will help you out unless you travel to Rochdale and I'll do it for you.
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    best place to get repair wire 000 979 009 ??
    Dec 2010
    Littleborough
    104
    Audi, about 67p or something
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    cheers Avus !!
    Sep 2011
    9
    Thanks Avus, Makes complete sense. Its nice to know someone with the same car has activated this CM/LH lights. I wasn't sure if we needed the wire or not. Now i know you do! Thanks
    Sep 2011
    9
    Thanks TheStreetman. Avus seems to have the perfect answer. The Audi Retro fit also nails it!
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Follow Helifella On Twitter
    Avus do you have the repair wires? Was trying this mod last night with Trups but we didn't install the wire. Also he noted things had changed under the dash on my new car. Do you know where to put the wire on these later models? Also need to double check the coding too, as i'm not sure what was inputted.
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Sep 2011
    9
    Just removed the dash cover as instructed and as Helifella says there has been a bit of a change down below! Any idea were the wire goes as Block H, port 12 isn't there :-(
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Hi Samboii,
    Can I ask where you bought the repair wire and how much it was?
    Regards
    HeliFella
    Sep 2011
    9
    My local Audi Garage and it cost £2.12.... but were do i fit it!!!
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Thanks, I will wait for someone to tell us before I go and buy one. Hopefully Avus Sportback can tell us???
    Regards
    HeliFella
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Update for you - see my thread below for follow me home feature & note NB at the bottom of my post.
    http://www.audi-sport.net/vb/new-a3-...ml#post1432614
    Regards
    HeliFella
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    new facelift cars have different CE modules, with 3 main big plugs as opposed to the 10 smaller plugs we have in the older cars.
    you need plug C pin 18 if you really want to do the wire route.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Sep 2011
    9
    So if i fit the wire and alter the coding via VCDS i should have Coming Home/Leaving home lights?
