Monster MotorsportEM Tuning
Results 1 to 10 of 10
    Oct 2011
    57
    IS THERE ANYONE WHO CAN CODE A CLOCKSET INTO AN AUDI A3 8P IN LEEDS/BRADFORD AREA
    Basically, i have a new S3 clockset needed to be put into my audi a3 2005, does anyone know where i can get them coded from or is there anyone that can code them for me? in the LEEDS/Bradford area cheers
    Fossie
    Rhubarb Triangle
    3,969
    I hope you are aware that the immobiliser is in the instrument panel and you will need to get a new key/keys to start the vehicle. You will need to go to an Audi dealer for that.
    Also the mileage will be different and you will need to either increase the mileage to the same as your car has done and/or inform VOSA for MOT purposes.
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    [QUOTE=mike foster;1425864]I hope you are aware that the immobiliser is in the instrument panel and you will need to get a new key/keys to start the vehicle. You will need to go to an Audi dealer for that.
    Also the mileage will be different and you will need to either increase the mileage to the same as your car has done and/or inform VOSA for MOT purposes.[/QUOTE
    He won't need new keys at all, just his keys need to be paired up with his new clocks, I may be able to assist if your willing to travel??
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    Fossie
    Rhubarb Triangle
    3,969
    I believe the immobiliser chip in the key fob is a 'one-shot' chip and cannot be re-programmed. The lock/unlock can be paired up ok but surely you cannot pair the new immobiliser chip in the new instrument panel with the old keys ?
    I am speaking about 2005 MY cars and later with the latest shape key fob.
    Oct 2011
    57
    Hi wesley, thanks for your reply, how far are you? i dont mind travelling on a weekend, and if its not as far as scotland lol then yes should be able to travel.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    I'm in Manchester, it's not actually me that does them its my friend, I'll ask him I he will sort it for you? Had mine done a couple I weeks ago!
    Oct 2011
    57
    yh cheers wesley, just let me know what your friend says, thanks. and when you got yours done, did it take long, were there any difficulties?
    Khufu's Avatar
    West coast of Scotland
    5,693
    mike, your correct that the chip in the key can't be changed. What they do is match the replacement cluster to ecu & keys as opposed to matching those to the cluster.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    Quote Originally Posted by ps44u View Post
    Takes about 10 mins mate.
    27,096
    Quote Originally Posted by wesley View Post
    Is this the same mate who was doing yours..........................
    Huh hurrrrmmmmm....................................... . how long did he take again?
  1. Any one in Leeds/Bradford with VAG-COM
    By A3 Craig in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th December 2011, 19:21
  2. Anyone in leeds / bradford with VAG-COM
    By A3 Craig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2011, 22:08
  3. How to re-code a RNS-E headunit to enable AUX IN - Leeds area
    By stucker in forum In-Car Entertainment
    Last Post: 19th May 2011, 22:00
  4. 8P S3 - P15*** - Leeds/Bradford
    By mitch78 in forum Spotters forum
    Last Post: 27th May 2009, 22:16
