Volks AutosJMB Retrofits
Results 1 to 9 of 9
    Dec 2007
    35
    Haldex gen2 service guide
    Hello all
    I've searched high and low, and can't find a guide for changing the oil/filter on the haldex gen2. Does anyone know where I might find one?
    I have been given a bottle of oil, rather than the mastic-gun style cartidge, and can't find any information about putting it in.
    Thank you, and sorry if I've missed an obvious guide.
    S38P's Avatar
    Istanbul, Turkey
    130
    AFAIK you need to pump it in. you can not just pour it in because of the bad location of filler cap. there must be a guide somewhere in the web.
    APR Stg3 GT2871R|APR HPFP|APR FMIC|Ported&Polished head with +1mm valves|Forged Build Engine|Gredddy catch can|oil filter relocation+oil cooler|Braille Battery|SACHS|SMFW|Forge shortshifter|VF Engineering motor and transmission mounts|APR DP+test pipe+Supersprint rear silencer|HR ARBs|KW V3s|HALDEX Controller|8 pot RS4 Brakes|18x8 ET45 Ultraleggeras (Matt Graphite Silver) |225/40/18 Advan A048|SPARCO Evo2 Seats with 4point harness|rear seat delete+stripped interior|Defi Boost & EGT|AEM AFR|
    Dec 2007
    35
    Thanks for that. Don't suppose you know if it's a 'fill until it pours out again' job, do you?
    Thanks again.
    S38P's Avatar
    Istanbul, Turkey
    130
    yep, you fill it until it pours out. your bottle is 1 lt right? mine left 250ml in the bottle after filling.
    Dec 2007
    35
    Thanks. Yep, I have a one litre bottle. I'll take a look tomorrow.
    The filter looks like it can be removed with a normal socket... depending on access.
    Thanks again.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    You need one of these : Gearbox Oil Pump For those hard to access Places 80/90 | eBay
    I have used mine so many times for diff/box oil changes.
    SiT
    Apr 2008
    Tyne & Wear
    98
    Have you looked at an independent to carry out that work..? a local in the north east doesn't charge that much and even Audi themselves are reasonable. If I was buying a car that someone said they had serviced the haldex themselves I’d walk away without batting an eye-lid, others wouldn't of course.
    Which region are you from..?
    Dec 2007
    35
    Quote Originally Posted by SiT View Post
    Hello
    I have considered getting it done elsewhere, but I would prefer to do it myself for various reasons:
    1) I will not attempt the work until I am 100% confident in what I am doing
    2) It is in my interest to do it properly! If the Haldex fails 2k miles after being serviced at a garage, I would have a very hard time proving they were at fault - doing it myself I can spend more time and take care to ensure it's done properly.
    3) I tend to 'over service' my cars. When just buying oil and filters, this is not a massively expensive thing to do, and provides peace of mind. If I were to pay someone to do all the work, it would get very expensive!
    4) I don't really care if people choose to walk away from buying one of my cars. I know this may sound a little short sighted, but my primary concern is maintaining my vehicles to a high standard whilst not throwing money away. I usually run cars to very high mileages (my current daily car is an 05' with 240,000 miles - serviced by me since new) and I am yet to have any failures other than wear and tear items. If I have a few people walk away when the time comes to sell, then so be it. Without wanting to sound arrogant, I take good care of my cars and have always found that a folder full of reciepts for high quality oils and genuine parts is more than enough to sell them quickly.
    5) I have lost count of the number of times I have had work done by a garage and then had to correct their errors/replace components they have broken etc etc. Simple things like having wheels put on with an incorrectly set air gun really wind me up.
    I think if I were to buy a car new and sell it within a year or two, I would possibly rethink, as I'm sure someone looking to spend a large amount of money on a car would prefer a dealer history, but given the time that I keep cars and the reletively low value of them at the end, I think a loving history is more valuable than a dealer stamp which essentialy proves nothing.
    I hope this doesn’t sound arsey, it's not at all supposed to, I just got carried away
    I live in Bucks.
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Just make sure you really know which are the correct nuts to drain / add the new oil!
    The master tech didn't at my local trusted independent, so they ended up funding me a nearly new diff unit after running my diff dry... TPS want £2,580 for a new diff unit...
    123d MSport coupe from the company
    2007 S3 in sprint blue - gone!
  1. Haldex service!
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2010, 23:46
  2. Haldex service
    By S3JSR in forum Parts Requests
    Last Post: 22nd September 2010, 17:11
  3. Haldex Service
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2007, 16:20
  4. Haldex Service
    By jonnydiesel in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd November 2006, 19:05
  5. haldex gen2
    By lankyandy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2005, 10:54
