Chris NottJMB Retrofits
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By NHN
Thread: Would removing the clocks/speedo then refitting same one cause any problem/coding?
    Oct 2011
    57
    I just wanted to confirm that if I remove the clocks/ speedos from the a3 to change the dials and LCD screen, then refit the same clocks, would I have to recode them ?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Im pretty sure you will need to recode them.
    Oct 2011
    57
    Even if they are the same clocks going back in?
    Khufu's Avatar
    West coast of Scotland
    5,693
    You wont need to recode as such but you will get a pile of errors. IIRC you will need to recalibrate ESP, steering angle sensor & brake pressure.
    help here:
    http://wiki.ross-tech.com/wiki/index...ctronics_(MK60)
    Oct 2011
    57
    Hi khufu thanks for your reply, I checked the link and it doesn't work, also if I were to unplug the battery and then remove the clocks would I still get the warning lights?
    27,114
    Usually if its the same clocks plugged back in after initial removal, the angle sensor etc should all clear on a drive, its when you plug in another cluster & then plug yours back in, is when it needs things resetting, but even if it decides to act up as in requiring resetting of things, just requires some simple procedures with vcds, IMMO shouldnt be affected at all with an unplug/plug scenario.
    Buttttt, be very careful with the pcb as to not damage it, as the cluster is the immo system as such, so beware
    Sandra likes this.
    Oct 2011
    57
    Thanks for your help NHN, i knew you would come through for me!
  1. Removing and refitting headlight switch in dash?
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2011, 19:40
  2. S3 Clocks Speedo to A3 TDi
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2009, 09:44
  3. Red filter in Dash/speedo clocks
    By ALPINE in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2008, 10:44
  4. Speedo Clocks
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2008, 16:41
  5. Removing/Refitting S3 turbo
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 09:44
