    Nov 2011
    Southampton, Hants
    19
    245/18 rs4 tyres on a3 sportback
    Hi guys
    New to the forum and looking for some advice...
    I have recently fitted rs4 245 18" alloys on my 2007 a3 8pa tdi. All went on better than expected but get some rubbing on the rear under heavy compression.
    Ive removed the infamous rubbing screws in the rear arches and its much better now, but slight get a slight bit of rub on the inner arch.
    Can i trim these inner arch bits or remove them all together? I know its not always clever fitting such big wheels but it does look too good to remove them at the moment...
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Whats the tyre size and rim width? 245/40/18?
    245 seems very wide, most of the guys on here would run 225/40 on 18s. You can always drop to a 35 profile tyre if needs be
    Nov 2011
    Southampton, Hants
    19
    They are 245/40/18s. I know its a bit excessive but couldnt help myself. The main reason i bought them was because the have near new tyres. Im not sure about the rim width but i know they have an offset of et50! With one passenger they are fine, suprisingly. Its only when i have a couple in the back that it becomes quite annoying.
    Thanks for the reply
    TimG's Avatar
    Feb 2004
    South Coast
    932
    What's the rim width? 245's are meant for 9" rims so are likely too wide for your wheels tbh.
    EDIT, possible skim read fail. I assume these wheels and tyres are from an A6 etc so might be that wide.
    You can trim the plastic thats sits around the screw hole to gain a little extra clearance... I have on mine.
    Nov 2011
    Southampton, Hants
    19
    Ive taken the screws out and trimmed the plastic behind it and has made it much better. Just need to have a go at the inner arches then! The alloys and tyres came off a rs4. Bargain at £400 for oem and new tyres!
    S38P's Avatar
    Istanbul, Turkey
    130
    any pics?
    APR Stg3 GT2871R|APR HPFP|APR FMIC|Ported&Polished head with +1mm valves|Forged Build Engine|Gredddy catch can|oil filter relocation+oil cooler|Braille Battery|SACHS|SMFW|Forge shortshifter|VF Engineering motor and transmission mounts|APR DP+test pipe+Supersprint rear silencer|HR ARBs|KW V3s|HALDEX Controller|8 pot RS4 Brakes|18x8 ET45 Ultraleggeras (Matt Graphite Silver) |225/40/18 Advan A048|SPARCO Evo2 Seats with 4point harness|rear seat delete+stripped interior|Defi Boost & EGT|AEM AFR|
  1. 245/40/18 Tyres x 4
    By 16VG60 in forum For Sale/Wanted - Audi Parts
    Last Post: 15th November 2011, 21:20
  2. Replies: 14
    Last Post: 6th November 2011, 21:56
  3. Anyone running 245/35 x 18" tyres on their S3?
    By Lizard-Racing in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2011, 20:45
  4. Tyres for 07 Sportback 225x40x18s
    By SMc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2008, 00:09
  5. Will 245/40/18 tyres fit a A4 B6???
    By Marc1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th June 2008, 13:47
