AH FabricationsVolks Autos
Results 1 to 7 of 7
    munchkincoupe's Avatar
    Aug 2010
    971
    140 or 170 clutch - which is best? - part numbers?
    Interested in doing the clutch on my car as just had remap and figure it will only be a matter of time before the clutch needs doing so wanted to keep a look out for parts now. It's a 3dr 2004 2.0 tdi manual gearbox on 52k miles and remap to approx 170bhp.
    If anyone knows the exact parts needed (presume clutch and DMF) and their part numbers that would be great
    Also is the clutch on the 170bhp 2.0 tdi a direct fit and is it a better clutch to fit
    Do any other model in the A3 range share the same clutch?
    Thanks for any help
    c_w
    1,061
    AFAIK the clutch on the 170 is the same as the 140. However on all models there is a confusion on what type of clutch/flywheel is fitted either Luk or Sachs and can only be known when the gearbox is off. Apparently they must be replaced like with like but I don't understand if you are changing for example the flywheel and the clutch that you can't just use either.
    Aug 2010
    971
    I've got a full Sachs clutch on the way but as I've only had one slight clutch slip yesterday I think the flywheel should be ok - fingers crossed I've not got the LUK fitted?!?
    Aug 2010
    971
    tdi-man's Avatar
    Jul 2009
    1,612
    DONT NOT BUY CLUTCH FROM THESE PEOPLE TECHNICLUTCH READ THERE FEEDBACK ALSO SEARCH THE INTERNET ON THE COMPANY NAME AND YOU WILL FIND BAD REPORTS .
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Aug 2010
    971
    Thanks - did search after posting it up - why doesn't Ebay get rid of them?!?
    Jord's Avatar
    Dec 2010
    Ellesmere port
    273
    I'd be interested to see prices of clutches, I've had mine remapped and I've got slight clutch slip
    Audi want £500 for clutch n dmf
  1. 140 vs 170
    By Bikerz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 19:15
  2. Replies: 28
    Last Post: 8th August 2011, 23:52
  3. What would you have and why ? 140 or 170
    By Lew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 16:18
  4. Economy - 2.0 140 chipped to 170 or Factory 170?
    By Addie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th April 2009, 23:40
  5. Clutch + Flywheel part numbers (AMK)
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2006, 17:50
