Chris NottJMB Retrofits
    Aug 2003
    291
    Identifying oem bluetooth model version
    I am looking to install an OEM bluetooth model in a 2007 A3 SB with Bose and concert head unit.
    I've read various threads listing different versions which distinct in their letter following the commmon serial number(K has firmware problems and D only has basic functionality)
    I've been sent the spec below
    9377D OB5372157
    HW ???8P1 862 335 H41
    SW? ??8P1 862 335 0650
    MANUFACTURE DATE 27 4 2011
    NEW UNUSED, SOFTWARE CODING IS CURRENTLY 0000000 AND DOES REQUIRE CODING DEPENDANT ON VEHICLE AND EQUIPMENT INSTALLED IN THE CAR
    THE UNIT WORKS IN A4 UPTO 2008 OLD SHAPE, TT AND A3 ALSO A2 IT IS K LINE AND CAN LINE COMPATABLE AND CAN BE WIRED TO BOTH TYPES OF SYSTEM.
    Ideally I want to pair to an Iphone 4 and have the full phonebook come thru on the DIS
    Does anyone know how to determine which version the above kit is?
    thanks
    Paul
    Nov 2008
    389
    You should be fine with that one - manufacture date suggests latest model - MY2011 units seem to have stopped with the usual letter suffix and just end at the 335 rather than having a K or D etc. I fitted the same revision to our A4 this year and all fine on all flavours of iPhone.
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Nov 2008
    389
    Do you have multi-function steering wheel?
    Aug 2003
    291
    Quote Originally Posted by phil_w View Post
    I do so hoping all the PTT etc will work
    Nov 2008
    389
    Should be fine then I think
  1. Anyone got a link to Audi version of this BMW OEM wheel site?
    By munchkincoupe in forum General Automotive Chat
    Last Post: 16th October 2010, 18:12
  2. OEM diverter valve version 'D' fitted :-D
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2010, 19:30
  3. Identifying an S3 facelift model ???
    By jq_quint in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2009, 22:11
  4. Bluetooth retrofit: US version on European A3
    By rbouzereau in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2008, 16:20
  5. what model is this 20" oem audi wheel from?
    By shufti in forum A8/S8 forum
    Last Post: 9th March 2007, 09:31
