Chris NottMonster Motorsport
Thread: Damaged damper
    May 2010
    274
    Damaged damper
    I've got a damaged damper that needs replacing and I've been toying with just getting a complete overhaul of the suspension inc bushes too as the car is rough as **** to ride these days - I remember when I first got it how smooth it was.
    The car has 140k+ miles on the clock - so it is wearing out!
    Just looking for reccomendations for the cheapest but still good quality dampers and springs to replace. I would quite like the best stability but smooth ride.
    I've got a 2006 A3 8P2 2.0TDi Quattro Sport - not particularly looking to get it lowered - maybe to the same as a S-Line which is 10mm less than I have at the moment I believe.
    Doesn't have to be coilovers - they're a bit too expensive. just dampers and springs will do! (Unless you really tempt me!)
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    If it were my decision I'd go for KW coilovers. Good ride quality, well built, warranty, and adjustable height if you do decide you want to lower the car slightly.
    Probably not much more expensive than a set of springs and dampers
  1. Anyone got a B6 damper kicking around?
    By aragorn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2010, 16:32
  2. Glovebox damper
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th August 2010, 11:25
  3. Timing belt damper
    By Matt82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2009, 06:57
  4. Broken Bilstein Damper
    By steve123a in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2007, 14:10
  5. Glove Box Damper
    By dkelly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2007, 15:33
