EM TuningAH Fabrications
    Jan 2011
    119
    Adjusting Xenon headlights trough vag-com a3 2.0tdi 140 8p
    Hi guys, just wondered, is there a way of adjusting xenon headlights using vag-com? i have the standard single xenon type, is there a way to set the level using vag-com? Also can you not set it up so you can use a switch for different levels? Also can i turn on coming home lights using vag com or is there added wiring involved?
    Chris
    Fossie
    Rhubarb Triangle
    3,969
    Xenon headlights should be auto-levelling. No user adjustment is allowed.
    Coming home lights depends on what your car is and whether or not it has the necessary wiring and control module.
    If you have auto lights and wipers then it can be turned on with VCDS (previously vagcom )
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    xenons can be adjusted or tested in VCDS under control module 55. if the beam is sitting low due to lowering the car than you can adjust the actual headlights by using the 2 screw points on the top of the headlight... i would recommend that you go to an MOT station to get this done properly however!
    if the beam is lower than usual for no reason then it could be that one of the sensors on the auto levelling has failed.
    you cannot wire the levelling system up to be manual as it is automatically done with use of sensors on both axles of the car on its suspension.
    coming home is really easy to do even if you do not have auto lights, have a look on the below guide how to enable it. i had this on mine for over a year until i retro fitted auto lights into the car and so now it does it the way it was made to.
    cominghomelights - Audi Retrofit
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    27,121
    Quote Originally Posted by chrisy t View Post
    As they said, vagcom will only set them at an mot mode as in set position so you can manually adjust on an MOT BAY only with the manual screws, then disable the mot mode, then its all automatic.
    CH/LH does have a hack, but its constant iirc, not only night time, hence why Mike advises about the light sensor requirement.
  1. Adjusting Adaptive Xenon headlights for European Driving
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2014, 16:26
  2. Adjusting Xenon Headlights
    By HIGGINS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2011, 15:29
  3. Adjusting Headlights for abroad.
    By Pornstarr in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2008, 21:06
  4. Adjusting headlights
    By Caesium in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2007, 21:02
  5. Adjusting headlights for Europe/S3
    By mdwyer in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2005, 22:44
