EM TuningSky Insurance
    Nov 2011
    10
    2006 A3 2.0 TDI Quattro Sportback rear tyre wear
    Hi all,
    New here and I come with a problem
    got an A3 that has worn out it off side rear tyre inner edge stupidly fast..... about 4mm in two months!!
    It has taken a 4mm tread depth tyre from the front of the car down the the cords on the inside edge in about 2 months, any ideas what this will be
    I already know about looking at alignment etc but do these cars have adjustable rears or not?
    also could it be possible a bush is warn and so making the wheel sit wrong?
    any info or suggestions greatly appreciated,
    ADAM
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    check that you don't have a broken coil spring on that side, common for the pig tails to snap on springs which would put your alignment out.
  1. rear tyre wear
    By alfie155 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th September 2011, 19:45
  2. Rear tyre wear
    By shawshankuk in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st March 2011, 18:59
  3. rear tyre wear ?
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2009, 19:48
  4. Rear tyre wear issue on non-quattro car!
    By AndymacA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2009, 20:57
  5. rear tyre wear
    By steveg9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2008, 20:23
