Chris NottAH Fabrications
Results 1 to 10 of 10
    Apr 2010
    Nottingham
    230
    S3 8P Xenon dipped beam seems low
    The xenons on my S3 seem to point really low down. When I start the car and switch the lights on they go through the diagnostics where the beam goes up and down and then settles. They just seem a bit low. I know the level is controlled from sensors on the suspension but is there anything I can check to make sure all is as it should be? VAGCOM shows no errors.
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    warren_S5's Avatar
    Oct 2007
    7,162
    I take it that it pssed it's last MOT; if so it would have been picked up that the lights were set up outside of acceptable range.
    Is the car lowered at all. I appreciate they are self levelling based on suspension set up, but have no idea if they recalibrate for cars with suspension mods.
    Worst case scenario, some Audi dealers are doing winter checks for £9.99 (Ridgeway Group are), so you could always pay the tenner and ask them to check it at same time.
    Audi S5 3.0V6T Coupe Black Edition
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    lowering affects this as mine are also too low since lowering the car!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    warren_S5's Avatar
    Oct 2007
    7,162
    Do you know how you recalibrate after lowering as I'm soon to be putting on Eibach Pro front springs which lowers front of car, not rear. Is it a mechanical adjustment using the rods, or a VAGCOM adjustment?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    i think you need to log onto module 55 (xenon control unit) and then it can be done under adaptation?
    found this on Ross Tech website: Ross-Tech: VAG-COM: Xenon Headlamp Adjustment
    edit:
    just found this thread which is also linked on the Ross tech site... explains what you might have to do on a lowered car to get the sensors working properly http://forums.vwvortex.com/showthread.php?2383036
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    also if its just a little lower and the levelling motor is working you could just adjust the headlights manually using the screws a the top of the headlight and just raise it a little to your liking
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Apr 2010
    Nottingham
    230
    Car is on standard suspension as far as i'm aware. Last MOT was fine. It's a shame my nearest Audi dealer is a bit of a way away. VW may do the same checks though I guess and they're a bit closer.
    TTRS FBMFSW
    MY11 Rear Lights
    Apr 2010
    Nottingham
    230
    Well the car was in for a few other issues and asked them to look at the lights. Apparently they were a bit low so have been adjusted. Can't wait to get it back to see if I can actually see where i'm driving at night!
    TTRS FBMFSW
    MY11 Rear Lights
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    Hi ,i had the same problem after lowering the car ,had to drive at 60mph all the way to Scotland from Cumbria in the dark ,could hardly bloody see a thing lol
    Mar 2009
    Staffordshire
    1,241
    Didn't really notice mine were any lower until it was recently put back standard after 2 and a half years and my God the lights are high now lol
  1. S3 Xenon dipped beam level
    By ADi Nuff Valves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2011, 22:38
  2. Halogen Dipped Beam Malfunction
    By ryanstewart9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2011, 18:22
  3. How to keep dipped beam on when using full beam???
    By Keithsri in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2010, 21:31
  4. Xenon dipped beam - down, switch off, normal again??
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2010, 08:59
  5. Sounds silly BUT is high beam brighter than dipped beam......
    By A3-frankie in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2007, 18:15
