- Joined
- Jul 8, 2008
- Messages
- 9,420
- Reaction score
- 641
- Points
- 113
55 plate 1.6
any help on the 01314 ?
Tuesday,15,November,2011,18:03:51:27402
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P06B006913 Mileage: 101080km/62808miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 EH
Component: SIMOS71 1.6l 2V 7004
Revision: --H01--- Serial number: AUX7Z0E7FNV02G
Coding: 0000071
Shop #: WSC 00046 412 08192
VCID: 69D2574F4062FD6
1 Fault Found:
16719 - Crankshaft Position Sensor (G28)
P0335 - 009 - Malfunction
Freeze Frame:
Bin. Bits: 00000100
Voltage: 3.020 V
Voltage: 0.620 V
Voltage: 2.940 V
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0019073
VCID: 4084AAEB1398DCE
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Chassis Type: 1K0
Coding: 0000071
1 Fault Found:
Freeze Frame:
Bin. Bits: 00000100
Voltage: 3.020 V
Voltage: 0.620 V
Voltage: 2.940 V
Revision: 00T12001
Coding: 0019073
1 Fault Found:
