Badger5JMB Retrofits
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 91
  1. #41
    27,016
    Send me a PM mate & we can discuss the possibility
  3. #42
    Fossie
    Rhubarb Triangle
    3,969
    It is possible to install CC without having a DIS (Driver Information System) but it is likely that you will need a new steering control module as well as the new stalk. Cost of parts is likely to be £250 ish plus fitting and coding.
    Depending on whereabouts you are in the country (assuming you are in UK ) then there are members of this forum who could do it for you.
    Have a search on the forum and see what you can find.
    Welcome to ASN by the way !
  4. #43
    Fossie
    Rhubarb Triangle
    3,969
    Bugger - you beat me to it !!
    Have you checked your inbox on the other forum ?
  5. #44
    Mar 2012
    15
    Its not the cruise control im wanting to get fitted, its the DIS. Is this possible?
  6. #45
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by danmckinstry View Post
    Sorry mate - my bad !
    Nige - he hasn't enough posts to PM so it's up to you
  7. #46
    Mar 2012
    15
    No bother mate. Ive been in touch with loads of garages around my way and its the same answer from all of them, impossible! But on many forums people say they have done it.
  8. #47
    Fossie
    Rhubarb Triangle
    3,969
    I bet NHN can do it - do you want me to PM him for you ?
  9. #48
    Mar 2012
    15
    If you wouldnt mind mate. How come i cant private message?
  10. #49
    Fossie
    Rhubarb Triangle
    3,969
    You need a minimum number of posts (not sure how many) before you can PM. You haven't enough yet !!
    I'll PM him.
  11. #50
    Mar 2012
    15
    Oh ok mate, thanks a lot.
  12. #51
    Mar 2012
    15
    Has there been any news on the subject lads?
  13. #52
    27,016
    Yes a dis can be fitted, but you need a dis cluster which requires immo coding, plus a new wiper stalk & maybe a sensor for the water level.
    Whereabouts are you located?
  14. #53
    Mar 2012
    15
    It already has a water level indicator (if your talking about the window washer fluid). I'm in middlesbrough mate. How much is all that going to cost about?
  15. #54
    Mar 2012
    15
    Would you be able to do it for me, if I came to you mate?
  16. #55
    27,016
    I'm in the south east, but yes it could be done.
  17. #56
    Mar 2012
    15
    Do you know of anyone in the North East who is capable of doing it?
  18. #57
    27,016
    Its finding someone who can code the cluster in, I may know 1 person but I have to ask him 1st.
  19. #58
    Mar 2012
    15
    If you would do mate would be much appreciated. Private message when if you get in touch with him because I think I've made enough posts now. Cheers
  20. #59
    Mar 2012
    15
    If I came to you mate how much would I be looking at paying?
  21. #60
    Oct 2011
    Grange-Over-Sands
    40
    Many thanks to jb0o for installing my Cruise Control.
    I had been waiting for months for my mate to get around to it (you know what its like) but I contacted Jonny on Friday and he installed it on Sunday.
    No problems whatsoever. Test drive. Service with a smile. Hassle free. Just what you'd expect from an expert retrofitter.
  22. #61
    Apr 2012
    Blairgowrie, Perthshire
    19
    Same issue with me - I had CC in my old A4, but the A3 I have replaced it with doesn't. Mines is 2009MY with the white DIS and the MFSW, so I assume all I need is the combined CC and indicator switch, a new lower moulding for the steering column, and someone who knows his way around VAG-COM to program it to the car??? Anyone have any ideas how much the switch costs?
  23. #62
    Fossie
    Rhubarb Triangle
    3,969
    CC retro-fit kit part no. :- 8P0 054 690 £62.29
    Lower cowl part no. :- 8P0 953 512 A £28.68
    These are ETKA prices from a dealer. Ring Dave at Stoke Audi for discounted prices but you will have to pay postage.
    Apart from VCDS coding you will also need a 12mm spline bit to remove the steering wheel
  24. #63
    May 2012
    Can anybody let me know a fitter in the Weston-super-Mare / Bristol area. I have fitted a multifunction steering wheel and have the stalk and lower cowl to fit cruise control to an 07 Audi S3.
    I need somebody to programme the car for me so the bits work. Any ideas???
  25. #64
    Fossie
    Rhubarb Triangle
    3,969
    Try this thread and click on a flag near you :- Audi-Sport.net VCDS Users - Google Maps
  26. #65
    May 2012
    Hi Guys
    Been reading through the posts and I've just purchased an A3 TDIE and am looking for parts and install for Cruise Control if anyone's in or near Bristol?
    Cheers.
  27. #66
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    I have a 58 plate S3(facelift) and have fitted Cruise Control myself.
    Bought it from Huntingdon Audi off eBay. Supplied my reg so I knew I got the correct one.
    Car was in at Highland Audi for a n/s/f wheel bearing(yes at 21k!!) and asked the tech to code it in.
    He came back to me when I picked the car up to say that he was unable to code it as the coding was not accepted.
    He also said that my RNS-E was not coded(which its not) and that may have something to do with it?
    I'm unsure why this would be?
    The RNS-E works perfectly well without being coded so wasn't that fussed.
    Has any one had any similar issues?
    Any info would be appreciated, cheers.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
  28. #67
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,607
    Lol, what a load of BS! Find someone close to you with VCDS and get them to code it in for you.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  29. #68
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,098
    As Jonny said, 9 out of 10 times, the dealers are clueless on retrofits and coding!
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  30. #69
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,334
    Quote Originally Posted by crunchie View Post
    Crunchie, few of the guys will be in aberdeen today, if you could get there, sure Mark will have his vcds on him. If not, try sending Mark (brodster) a pm, he will be up in elgin area in the next few days to take his kids home, so he may be able to help you out.
  31. #70
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by Sandra View Post
    Thanks for this Sandra. Unfortunately I'm off shore until Thursday. I may PM him to try and arrange something for when I get back.
    Thanks again.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
  32. #71
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    is there anyone in the South that does the CC retro fit? Near to portsmouth as possible, i dont have a MFSW but have the computer, sombody got a rough price in mind?
  33. #72
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,334
    Quote Originally Posted by chris.vincent3 View Post
    Try user dannykn9. x
  34. #73
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,334
    Thanks again.
    ok Crunchie, if you can get to Banchory on the 28 th let me know and i will organise a vcds scan time for you. x
  35. #74
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,098
    Cheers Sandra.
    Chris, have sent you a PM mate.
  36. #75
    Ginger Prince's Avatar
    Aug 2012
    Manchester
    189
    Quote Originally Posted by Dannykn9 View Post
    Cheers Sandra.
    Hi all,
    I live in Manchester and have an Audi S3 (8P) with the trip computer.
    Im looking to also have cruise control fitted (probably October).
    Is there anyone near me or in the North West that can be be recommended and how much am I looking at please?
    Mike
  37. #76
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,098
    Hi mate,
    I sometimes drive to Manchester, but otherwise you could get a user here called N8 to arrange it for you as he is set up around Manchester. Sure he will look after you and sort out a good price.
  38. #77
    Apr 2011
    41
    I'm looking for someone to retrofit the cruise control for me please,
    53 plate 8P with Trip computer
    Im in the East Midlands
  39. #78
    27,016
    Ping me a PM mate as I have work in that area soon
  40. #79
    Aug 2012
    Manchester
    189
    Audi S3 2008 Built (8P). Retrofitted Cruise Control. NEW ECU or no ECU?
    Hi mate,
    Cheers Danny, Nigel said the same so i'll see if I can find him on here.
    Mike
  41. #80
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,098
    Quote Originally Posted by Ginger Prince View Post
    Mike
    Here is a link to Nathan's (N8) profile where you can PM him fella.
    View Profile: N8 - Audi-Sport.net
  1. B5/B6 A4 Built 2.0l 20v stroked engine/manis/ECU
    By jcb in forum For Sale/Wanted - Audi Parts
    Last Post: 8th November 2011, 20:49
  2. anybody retrofitted cruise control on there 8l?
    By sportstractor in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2010, 12:14
  3. ECU problems - attempting to match Immobiliser with ECU....and failing
    By stefanhenchoz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2010, 18:44
  4. Cruise Control retrofitted
    By gregormac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2009, 09:02
  5. Right ECU/Slip-ring for cruise?
    By Von Maximo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th April 2008, 23:22
