Chris NottJMB Retrofits
    BaDD Boi S3's Avatar
    Audi S3-REVO-Digital Designs
    Jul 2011
    South Africa
    40
    08 S3 Rattle between 2700 and 3000 RPM
    Hi Guys,
    Just wanted to know if anyone experienced this rattle on their 2.0 TFSi motors and what the possible causes could be?
    Basically when you accelerate slowly through the rev range at the above mentioned engine RPM there is a rattle but as soon as the car boosts its gone?
    It would do this in any gear as long as the accelaration is steady, if you plant it you do not notice the noise but it might just be drowned out but the performance exhaust? Best way to explain the sound is if you think of a Diesel motor sound whilst between the mentioned RPM, if you play with the accelerator in this range the sound is there when you push down and gone as soon as you release the pedal.
    I have read that VW owners have a noise between the revs mentioned and some Audi owners also experienced this noise and tat VW released a TSB stating that its the wastegate and that a weight needs to be attached to resolve the issue.
    Would you say that the noises are the same and that I would need to get my wastegate looked at or am I experiencing something else?
    link to the TSB = http://forums.vwvortex.com/showthread.php?5107473-FYI-Technical-Bulletin-on-all-2.0T-engines-from-2008-to-2010
    Thank you in advance
    Rgds
    BaDD Boi S3
    8P – Ibis White – Lamin-X’d – Custom 18” – Smash n Grab – Dropped Suspension - DRL
    Rain n Light – Cruise Control – Silk Napa RS4 Seats – Sunroof – PDC – LED Package - Auto Dip Mirror
    REVO Stage 2+ (All Bells n Whistles incl.) - DevilSown - CAI Kit
    Drag Wars Champion – 13.0s ¼ Mile
    215.3 wkw - 461Nm
    Acoustic Audio - Custom Sound Installation:
    Digital Designs 9515 – DD M3 Amp – Infinity KaPPa Splits – Optima – Batcap – Damplifier Pro – JVC DVD
    warren_S5's Avatar
    Oct 2007
    7,133
    Could be that.
    My initial thought was this: TSB Link - S3 8P3 Valve spring issue
    Audi S5 3.0V6T Coupe Black Edition
    Jul 2011
    South Africa
    40
    Thank you Warren,
    Will indeed let them have a look at this as well
    Rgds
    BaDD Boi S3
    215.3 wkw - 461Nm
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by warren_cox View Post
    Could be that.
    Thought this problem was 8P3 only??
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Jul 2011
    South Africa
    40
    Hi Guys,
    to add to crunchie's question would this sound develop over time or would this be there from the get go?
    My car was supper quiet and now started this after it went for the 70k km service?
    Thank you in advance!
    Rgds
    BaDD Boi S3
    215.3 wkw - 461Nm
    warren_S5's Avatar
    Oct 2007
    7,133
    Quote Originally Posted by crunchie View Post
    Not sure TBH, was led to believe it was '08 cars that this issue started with, but unsure of whether 8P3 in manufacture at what point in the year, or whether it was in response to a change of spec to 8P3. The main dealer should be able to tell from the VIN bumber whether this TSB affects this car.
    As much as I'd love to confine it to a particular range of cars, with various production lines and parts sourcing for different models you can never quite tell (at the consumer end) what gets put in what and when. This car is in South Africa and they were still making Mk1 Golf's up until about 2 years ago, so whilst I'd hope a 8P2 spec is the same in the UK as it is anywhere else I'm genuinely not sure for international production consignments!
  1. Help, S3 missfire and black smoke between 3000 rpm and 3750 rpm
    By sportquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2011, 16:56
  2. S3 speed at 3000 rpm?
    By Ivo in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2009, 18:10
  3. Power loss at 3000 rpm
    By crusher in forum General Technical / How To
    Last Post: 6th March 2008, 21:04
  4. 3000 rpm
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2006, 15:48
  5. Power Dips @ 3000 RPM on S4???
    By imported_grantos in forum Tuning
    Last Post: 12th August 2004, 13:35
