JMB RetrofitsBadger5
Results 1 to 29 of 29
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,390
    Question S3 Boost Modulation/Flutter
    Hi guys,
    My S3 has always had this since going to Revo Stage 1, but now I've just fitted a ITG CAI (See here: Silky's S3...) its now much louder (to be expected) and just though I'd check with your guys.
    So on WOT or 80%+ (I.e not when letting off the throttle, so its not DV noise (I do get this though, but thats nomal)) I get something that sounds like turbo flutter/modulation. It sounds like the turbo is pulsing on and off very quickly, with a air sounding 'psst' noise. It has no effect of performance and the car pulls strong all the way through it. It seems to happen between 3k to 4k and then stops.
    Nomal? I seem to remember Awesome GTI saying this was normal when the car went to S1 due to the higher boost pressures, but now its a bit louder just thought I'd check!
    The car pulls well strong so I don't think anything is amiss!
    Also - on that note, anything I can log in VCDS to check the boost is ok etc? Requested vs Actual? Any advise?
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
    s3ollie's Avatar
    Jan 2007
    749
    Think i have the same problem as you. The problem logging boost is that if its a small leak the turbo will over boost to make up for the leak and it still make the requested.
    I have done a pressure test to 1.5bar and there are no boost leaks on mine i think my problem is the rocker gasket is leaking letting out blow by gas as there is some oil on the back of the gasket.
    8P S3
    Silky-S3's Avatar
    Jan 2009
    1,390
    I don't think my issue is a problem so to speak mate, and I as far as I know I don't have any boost leaks. The car pulls very very strong and its only 9 months old. No oil leak/marks on the block or turbo as well.
    Ive been searching round and it seem that this is common on TFSI 2.0 lumps once remapped. It seem to be the ECU modulating the boost and it happens even on the OEM map but as the boost it so low you can't hear it.
    Anyone else got an idea?
    Quote Originally Posted by s3ollie View Post
    Build Thread Here!
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Do you mean like a fluttering type sound?
    Audi S3 8P2 Silver
    BI-Xenons - FBMFSW - Rain/Light Pack - Auto dim package - iPod Integration - 2011 Nav - Electric Folding Mirrors - Rear Park Sensors - Full Heated Leather - BOSE - Privacy Windows - 2011 Console Conversion - My11 Rear Lights - RevD Diverter - Forge DMV14T BOV - ITG Maxogen CAI - BBS CH 18s
    Silky-S3's Avatar
    Jan 2009
    1,390
    Quote Originally Posted by S3 MRU View Post
    Yes mate, that's right.
    Build Thread Here!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    if its part throttle then the constant change of vaccum then positive boost pressure will make your piston dump valve 'flutter' a little.
    is your DV aftermarket? make sure you have the right spring
    edit: just re-read you said WOT. it could be surge i suppose? although im not sure how likely that is
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    It's normal - I still get it with the Forge DV but not as much when I was using the RevD diverter from Audi.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    I have the rev d. Diverter and forge spacer and it never did this. Now I fitted my itg maxogen Cai. It makes this noise. I recorded a video of the sound mine makes now. It's reverb from the turbo with excess air and how it's dealt with by the dv. It's completely normal
    http://www.youtube.com/watch?v=sxdw3m90uku
    Audi S3 8P2 Silver
    Silky-S3's Avatar
    Jan 2009
    1,390
    Cheers mate, cant see the vid but thanks for the info. Puts my mind to rest!
    Build Thread Here!
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    If you type michelerusso88. In YouTube. Find the itg video
    Audi S3 8P2 Silver
    Silky-S3's Avatar
    Jan 2009
    1,390
    Yep, thats the sound mate. Thanks!
    Build Thread Here!
    Jun 2010
    221
    Mine makes it, alot.. constantly.. usually if you tap the accel through gears, or if you are really light on the accel just puttering around.
    This audio is taken from a "drive" so you can hear the intake/flutter i guess.
    here clicky
    Silky-S3's Avatar
    Jan 2009
    1,390
    OK, cool. Sounds like mine
    Build Thread Here!
    Jun 2010
    221
    blue s3, sounds like mine.. bloody copies! :P
    TimJK's Avatar
    May 2011
    Norwich, Norfolk, United Kingdom
    407
    I've been pointed to this thread since I questioned the noise on mine after a revo stage 1 map, still not convinced its normal mind you.
    Fairly sure it holds back while the boost flutters, running yellow spring, maybe I need the next one up so it holds the valve shut rather than letting out boost?
    Silky-S3's Avatar
    Jan 2009
    1,390
    Its totally normal mate been confirmed by loads of people/tuners. It sounds ever better now Im at S2+! I've done tons of logs (and have a boost gauge installed) it does not lose boost pressure when doing it.
    Build Thread Here!
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by TimJK View Post
    Mine too hesitates but only when on full throttle, especially at the start of 4th, I figured it's because of needing fuel pump upgrade. (I'm stage 2)
    When I get stage 3 rolling hopefully this will be solved in the new mapping.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Silky-S3's Avatar
    Jan 2009
    1,390
    Quote Originally Posted by mjr901 View Post
    Be careful with that mate, might be leaning out due to a lack of fuel. Get a HPFP installed ASAP.
    Build Thread Here!
    TimJK's Avatar
    May 2011
    407
    Yup that's when mine does it full throttle only, you can half throttle though 3500-4000rpm and it won't do it. Mine is from 2nd - 6th gear though
    s3ollie's Avatar
    Jan 2007
    749
    Quote Originally Posted by Silky-S3 View Post
    Have you logged your requested Vs actual fuel pressure. On mine the actual was dropping 50 bar when i heard the noise (3-4K). It wasnt running lean as i logged AFR and lambda and all was ok, it was opening the injectors longer to make up for the loss in pressure, however I couldnt live with it and had the map removed.
    8P S3
    Silky-S3's Avatar
    Jan 2009
    1,390
    I have mate, loads of times as setting the map up with SPS. I'll see if I can dig out a graph for you.
    Build Thread Here!
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Yeah I planned to do it this month but for some reason the mrs's Clio needed to be purchased? so I have to wait till next month now!
    i can't see it being my dv, cars 3 months old. So perhaps all the hesitation issues are fuel pumps not keeping up? I spoke to a Revo dealer a while back and they said some people struggle at stage 1 with their maps with the standard pump. I knows there's plenty that don't, but some maps may do?
    Silky-S3's Avatar
    Jan 2009
    1,390
    I did my HPFP at S1 and it made a big difference at high revs, confirm by logging requested vs actual rail pressure.
    Build Thread Here!
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    If I were to start again with all this modding, the HPFP would be no 1 purchase, then the maps and bolt-Ons to follow after.
    Ill get it read when I go stage 3 and check everything is OK, i dont think it's going to go bang any time soon, it's been stage 2 from new ( now 6.5k miles)and nothing significantly wrong. I don't have VCDS but shark will roll on next month...
    Silky-S3's Avatar
    Jan 2009
    1,390
    Good advice mate!
    Build Thread Here!
    TimJK's Avatar
    May 2011
    407
    Do you think it's something to do with me having standard fuel pump on a stage 1 map then?
  28. #27
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Does the HPFP increase fuel consumption significantly on Stage 1?
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
  29. #28
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Well the flutter is normal, but any great hesitation is probably due to the mapping/fueling. I think you should get the car read by VCDS and see if fuel requested is being met.
    If it is, then no need to jump into fuel pumps unless you want to go further, i.e stage 2 or more.
    If the fuel is being met, what else could cause the hesitation? Perhaps change the spark plugs for some cooler ones?
    Make sure your using High octane fuel.
    Contact revo for some finer tuning, Im sure they can fiddle with it somehow and make it more refined. My friends golf TFSI 2.0 stage 2+ REVO has seemless power. no hesistation, nothing, Just whaaaam. They did have the car for a week or so as they used his car as a test car for new software. So they are capable of producing good maps, probably just need to spend a bit more time with it at a guess.
    My shark maps no different. It needs refining, but that will be at tackled stage 3.
  30. #29
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    yep, think that map has to be properly tweaked for each car.. mine is going back to garage soon to get it 100% set for my car and crappy fuel that is sold over here..
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  1. Turbo 'Flutter'
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2010, 21:13
  2. Wastegate flutter?
    By s3 Hoggy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2010, 13:30
  3. Rev Flutter at -5
    By bl_1969 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2009, 09:01
  4. 1.8T flutter
    By mebrown001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2005, 17:28
  5. Diverter Flutter
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2004, 16:43
