Results 1 to 21 of 21
    NITRO
    Aug 2011
    80
    Rear wiper gone crazy!!
    My rear wiper on my audi a3 has decided to play up. When i activate the rear wiper it operates fine and then decides to get stuck and once i flick the wiper indicator arm it starts operating again? I've also noticed the rear wiper will come on when its off? Any ideas on what can be causing this?
    NITRO
    Aug 2011
    80
    I guess i need a new wiper motor maybe?
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    mines gone mad too! almost sounds like its grating the back window off!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    NITRO
    Aug 2011
    80
    Its gone bonkers! Am going to check if the water isn't getting blocked thats causing this issue
    Fossie
    Rhubarb Triangle
    3,969
    Water has got into the wiper motor switch mechanism. This is due to a washer leak at some time and cannot be repaired ( I tried !! ).
    Only answer is a new wiper motor and be careful - do not just go for one on ebay that says it will fit A3 because although some will fit, others have a washer nozzle that does not revolve with the wiper blade. This is for the Mk4 Golf and will not work with the A3.
    I got my local friendly VAG specialist to get the right one and paid £82. Fitting is dead easy.
    NITRO
    Aug 2011
    80
    Thanks Mike i'll give that a go
    NITRO
    Aug 2011
    80
    omg i think i might have got to the problem too late . I noticed the boot light came on to show boot open and it wasn't? Last night the alarm decided to randomly come on, off on off so i decided to remove the boot cover and found signs of water and decided to remove the rear motor but i can seem to remove the wiper arm?. I've remove the 3 bolts from the motor and the bolt & nozzle from the wiper arm, any ideas how i can remove wiper motor, does it just pull off?
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Quote Originally Posted by k9audi View Post
    WD-40 it, leave it for a bit then yank it! or so ive heard!
    S
    NITRO
    Aug 2011
    80
    cool i'll give that a try
    Fossie
    Rhubarb Triangle
    3,969
    It will come off but as said, WD40 for a while and then gently work it backwards and forwards and side to side and it should free itself.
    The boot light and alarm problems are all associated with water in the lock microswitch which will need to be dried out ( hairdryer ! ) I took the lock off and took it apart to get to the switch but that is probably not necessary.
    Main thing is you need to identify the cause of the leak and rectify that before the winter. Those push-on connectors do not work properly once they have been split and I used a tie wrap to secure the washer pipe. Make sure the pipe does not leak anywhere else on its' route from the washer bottle and importantly ensure that you have at least 50/50 washer fluid to water mix to stop it freezing. That's what causes the leakage when the pipe pops off due to being frozen.
    NITRO
    Aug 2011
    80
    Cheers mike i'll give that a try...
    Any recommendations on where i can get the wiper motor cheaper than the main stealers?
    Fossie
    Rhubarb Triangle
    3,969
    Only thing I can suggest is you go to a VAG independent and ask them. They may get one for you or tell you who supplies them. Problem is you may have to have an account to buy it !
    Either way you should expect to pay £80 - £100. Many of the ones on ebay that are cheaper will not be suitable even though they say they are !!
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    when i first got my A3 (private sale) i noticed the rear wiper was sitting on the wrong side of the rear screen so it was one of the first things i changed on it, i used it to haggle the price down
    the car was a state when i first saw it...
    when i tried to take off the rear wiper it wouldnt budge and i had to resist wacking it with a hammer as i knew i would shatter the rear screen but like others have said i used WD40 and lots of elbow grease and wiggled and pulled the damn thing off... the motor had seized but i managed to get a replacement one from ebay for about £60, almost 2 years now and no issues since
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    NITRO
    Aug 2011
    80
    I've been wiggling the damn thing side to side with wd40 and it doesn't seem to pop off. I did notice it feels abit loose so i'll keep trying. Do i have to remove the rubber gromet or do i leave that where it is?
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Grommet stays. If you spray wd into the nut recess until it actually fills up and half submerges the nut you can leave it overnight, this helped get mine off no end.
    NITRO
    Aug 2011
    80
    Thanks guys it finally came off. Just waiting for the wiper motor
    monster_munch's Avatar
    Dec 2011
    149
    Ive got the rest of the week off work and decided tomorrow Im going to have a look in my motor, make sure its not gunged up, then stick a tie wrap round the fluid pipe into the motor to keep it secure.
    Anyone got any info or pics on how to remove the tailgate trim to get access to the motor?
    Fossie
    Rhubarb Triangle
    3,969
    Please do a search mate - this has been covered many times !
    Dec 2011
    149
    Ive done a search mike, Ive just read 3 different threads, one of which where you told someone else with the same problem to do a search. In none of the oher threads is there any pictures or detailed info how to remove the tailgate trim, there is also nothing about it in my Haynes manual !
    Fossie
    Rhubarb Triangle
    3,969
    Sorry mate - pictures are not necessary ! You don't say if your car is a sportback or not but mine is and this is what I do.
    Remove the two torx screws ; remove the two plastic covers that allow access to the rear lights ; place fingers in hole on one side and jerk downward very firmly.
    Do the same on the other side.
    The trim WILL come off but you have to be seriously tough with it.
    The problem is that most people are frightened to do it hard enough in case they break something ! The whole thing is fixed with about 6 spring clips, apart from the two screws, and it is possible that a few bits of plastic may break.
    Don't worry, everything can b e replaced !!
    Dec 2011
    149
    Cheers for the info Mike, whilst searching google Ive found a useful pdf of an audi workshop manual that says how to remove it aswell.
    I have a 3 door, will give it a good go tomorrow.
    Normally I wouldnt worry about such things, but I read on one of the threads that someone had to have their £500 bose amplifier replaced because of leaking fluid, so better safe than sorry!
  1. rear wiper
    By lnewland in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2011, 08:33
  2. A3 Rear Heated Window and Rear Windown wiper problem
    By brettsh555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2011, 19:49
  3. Rear wiper
    By nig63 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:55
  4. Rear Wiper ??
    By MikeSel^ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st December 2008, 17:41
  5. Rear wiper - do they all do this??
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2007, 13:41
