Volks AutosSky Insurance
Results 1 to 8 of 8
    Feb 2011
    Coventry
    59
    Coding Help, Engine module, coding 11 access key required?
    Hi, Im retro fitting cruise control to my a3, ive fitted the stalk and coded the steering wheel ecu but im stuck at trying to code the engine module. i understand that i need to change the code in engine 01 "coding 11" but its not highlighted in vcds. do i need to enter a security access pin into it before i can change the code? any guides ive read dont mention any of this.. any body got any ideas??
    Audi A3 2.0TFSI S line DSG SB BLUEFIN
    Fossie
    Rhubarb Triangle
    3,961
    Is it genuine VCDS ?
    You don't say what year your car is but if you have the cable installed between the steering module and the engine module then VCDS should come up with the necessary information without requiring a pin number.
    Presumably you have researched all the threads regarding CC to see the basic requirements of hardware ?
    Feb 2011
    Coventry
    59
    yes, Why?
    Feb 2011
    Coventry
    59
    Got it from Nige
    Fossie
    Rhubarb Triangle
    3,961
    Sorry Ricky - just edited my post - please read again
    Feb 2011
    Coventry
    59
    Its a 56 plate 2.0tfsi with dis, no multi function steering wheel. i am sure that my steering ecu is the right one, how do i get hold of the security access code anyway to open up "coding 11" in engine 01
    Fossie
    Rhubarb Triangle
    3,961
    I don't know how you get hold of the code mate - sorry ! If the wire is in place between the steering control module and the engine control module then when you access the engine module VCDS automatically displays a number to put in to activate CC. It's something like 11463 but I can't remeber exactly. A little box pops up with two numbers - Cruise control fitted ..... and Cruise control not fitted ......
    This is what happened when I fitted CC.
    Feb 2011
    Coventry
    59
    Thanks for your help mike, i will doudle check that i have the correct sw ecu fitted and also for the wire.
  1. Central Electronic Module - Coding
    By drsilviuro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2013, 16:13
  2. CE module coding question
    By Khufu in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th July 2011, 12:19
  3. Roof Module Fitting - Is Coding an Issue???
    By kevin00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2011, 10:08
  4. Coding Comfort Module
    By Acidic32 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st December 2009, 11:53
  5. coding a new key?...
    By mrpies in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2009, 17:54
