AH FabricationsVolks Autos
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By flying oyster
  • 1 Post By vw754
  • 1 Post By Daft Old Sod
Thread: How to remove and replace A3 (2004) o/s headlight bulb?
    Reedswood
    Question How to remove and replace A3 (2004) o/s headlight bulb?
    Hi
    thought my plastic pig was hard to work on, but it seems the A3 is, too!
    Can anyone give me a step by step walk through on how to change a front bulb, please?
    btw, has anyone tried Halford's 'Brightest' bulb selection?
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    545
    having childs hands is a good start or get halfords to change bulb !
    plastic cover on back of light pull of metal clip that holds it and locate bulb and replace
    Reedswood likes this.
    S3 8L ming blue westys old car shed loads of mods
    Reedswood
    it's not the parking light I want to change, it's the main dipper bulb which has the big black box over it which seems impossible to dismantle...as you say, a child's hand is preferred!
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,969
    remove cover(obvious) its a 2 pin bulb......press down slightly on one of the bulb pins or the connector and the bulb will come out........when re-fittin seat the bulb in at the bottom first then push the top of the bulb forward....it clicks into place.
    Full leather/19"wheels/cruise/
    Daft Old Sod's Avatar
    Sep 2011
    14
    Changed mine the other day, 2007 so presume the same housing. There is a snap on cover on the back of the headlight housing that unclips to give access to the bulb holders. As Flying Oyster says, it is an advantage to have small hands & long fingers, though I managed OK with my stumpy little digits. Just pull bulb holder away from lens, feed through opening on back of unit, change bulb & replace.
    Reedswood
    boy, my knuckles are shredded after that fiddling around; even more so the passenger side...was a little difficult trying to push it in right, but finally succedded!
    Aug 2003
    291
    i just changed the dipped bulbs but the alignment is now way off, any tips on re alignment?
    L80EWY's Avatar
    Sep 2009
    331
    Wouldn't bother asking halfords, asked them to do my main beam when I first got the car an they ended up doing my full beam
    Reedswood
    yeah Halford's charge £7.99 per bulb to fit...forget that!
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    Quote Originally Posted by L80EWY View Post
    lol just read this Main beam is full beam dipped is low beam so they did what you asked of them.
    Growing old is mandatory, growing up is optional
    Reedswood
    I note Halford's are being scrutinized in BBC Watchdog next week; should be interesting on what they've found!
  1. How to remove/replace foglight S3?
    By 330_2_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2013, 17:01
  2. Bulb cracked - now to remove headlight lense
    By davej_anderson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2009, 20:46
  3. Front Indicator Bulb Replacement - Remove Headlight?
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2009, 08:07
  4. replace headlight bulb
    By audicion in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 15th August 2008, 09:36
  5. How to replace a Xenon bulb???
    By alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2007, 18:17
