    _G_
    _G_'s Avatar
    Jul 2011
    869
    Post Can anyone tell me what size rear brake discs I have?
    I have three options:
    Option 1:
    Diameter: 256mm
    Height: 48.3mm
    Thickness: 12mm
    Option 2:
    Diameter: 253mm
    Height: 51.3mm
    Thickness: 10mm
    Option 3:
    Diameter: 282mm
    Height: 48.2mm
    Thickness: 12mm
    Checked boot and PR number is missing/no sticker there with vehicle info.
    Thank you.
    May 2010
    London
    334
    And your car is????
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Sorry about that...
    Audi A3
    2.0TFSI
    2007
    8P1
    Thanks.
    Fossie
    Rhubarb Triangle
    3,969
    2007 can't be 8P1 !!!
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    stick your reg number into here
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Cheers. I was using a website called nextdaybrakes and it listed these three options for an 8P1.
    Thanks @marknjayne...
    Running 240hp... do I need grooved/slotted?? The brembo prices on nextdaybrakes for solid/internally vented discs look too good to be true...
    Reading around the slotted vs solid debate and a lot of sites are now saying that these days solid discs are quite good that they don't suffer from gas build up like they used to back in the days...
    I don't do a lot of heavy braking bar one particular busy town I go to on the weekends and people cross the road wherever they feel like it.
  1. Rear Brake pads/discs...
    By Wozski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2010, 17:02
  2. Rear brake discs...
    By S3 Paul in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th May 2009, 12:48
  3. size of front and rear discs???
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2008, 22:54
  4. Brake discs incorrect size?!!!!!
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2007, 19:36
  5. Correct size brake discs for A3 TDI
    By f13ldy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 13:34
