Results 1 to 9 of 9
    Dec 2007
    35
    Later climate control unit in 2004 car?
    Hello all
    I read somewhere that a late spec (chrome knob) climate control unit would not work in an early (2004) car.
    Is this true? I converted my car to double din today for my RNS-E, and thought I would try a late spec single din control unit I had lying about. It appears to be working ok?
    Anyone have any information on this? Have I been misinformed, or have I just not noticed something not operating properly? Or perhaps there are different versions of the facelift climate unit?
    Would be interested to hear your views,
    Thanks.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    No it does not work fully.
    Dec 2007
    35
    Can you shed any light on what doesn't work? I have just been out testing it and cannot find any issues?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Nigel explained it in a different thread, it doesn't fully work.
    Dec 2007
    35
    Very helpful.
    Baffles's Avatar
    Oct 2011
    London
    223
    Interested to hear the answer if anyone has one as this is something I'd like to update in my car.
    A1 | 1.4 TFSI | S-Line | Misano Red
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Quote Originally Posted by PhilPD View Post
    Very helpful.
    I'm not as helpful as the 'search' button
    BBlackburn's Avatar
    Jul 2011
    Epsom, surrey
    395
    There are technical differences that will not allow it to function properly, it may give you the impression its working if you dont change the direction of the air via the climate buttons, but once that is changed, it will be fairly obvious.
    There are no coding options for the Hvac 08, there is a basic setting option, but that wont fix this issue, as its mechanical & wiring.
    Do your research before assuming something will work, I spent ages on this, checked the wiring schematics which as you can imagine are a fair few wires on each version, I even created a spreadsheet to show the differences to myself when I come to swap the heater system over.
    There is no way in hell your units are working fully.
    Remove the glovebox, check the 2 motors behind this which have blue plastics, the big flap thats controlled via the 2 motors will not move properly as it did on the prefacelift climate.
    Sorry but you're wrong, it will not function fully.
    Impossible to fully work with a 54 reg car, totally impossible, as I have tested my research on a 54 reg, you IMHO misunderstand how the climate should work & when the AC button should be lit, they didnt change climate/heater system components until mid 07, 08 onwards, so its impossible to function properly in your car, that is a fact, even ELSAWIN advises the changes after I found the issues & did some more reading.
    Exactly, it wont be working as per the facelifts do, the led would be working in reverse.
    No, definitely not, I have proved this on a 54 reg car myself, I can show anyone the proof if need be.
    What happens is, when you initially plug it in, it will appear to work properly, but as soon as you tell it via button presses to move the big flap behind glovebox, it will be stuck after that & wont move back, given the 2nd motor isnt in use on facelifts, hence the plastic orange cam system which N8 will confirm is behind his 08 glovebox.
    This is what he said.
    SPEC: ebony pearl black ~ auto lights ~ auto wipers ~ half leather/suede interior ~ armrest ~ anti dazzle rear mirrior ~ coming home/ leaving home function.
    MODS: flat bottom steering wheel ~ bluetooth ~ cruise control ~ rns-e ~ MY09 rear lights ~ s3 pedals ~ s3 air vents ~ LED interior light pack ~ facelift buttons ~ dension ~ SDS ~ Aliminium inlays ~ full grille conversion.
    FUTURE MODS: lower ~ black edition rear ~ s-line/facelift front ~ black headlining ~ BBS CH-R or Speedlines.
    Dec 2007
    35
    Thank you, BBlackburn.
  1. Climate control unit
    By dannyFR+tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th June 2010, 16:58
  2. Climate Control Unit
    By maz1975 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 15:44
  3. climate control unit
    By imported_turbonutterb in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2005, 22:57
  4. climate control unit !!
    By Mcgough in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2004, 00:36
  5. 95 A4 Climate control unit
    By imported_Astwell in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2004, 12:01
