Hi all my name is Lee and I am new to this forum.
I have recently bought an 2006 A3 2.0 TDI. After having to replace the turbo within weeks I am now faced with the yellow emissions control light.
I have has it on a fault machine and it has come up with the following codes
19559 - P3103 - intake manifold air control actuator
P0682 - fan electrical fault.
I assume that I need to replace the intake unit ( I am going to take it off and clean first to see if that helps before shelling out £200 +)
After reading other threads on here I thought that the other fault would be fuse 8 blowing - however no luck. The fuse is ok, so just wondered if anyone else had been faced with the same problem or if anyone had any advice
regards lee
