Chris NottMonster Motorsport
Results 1 to 7 of 7
    Black 1997 Audi A3 1.6
    63
    Question Thinking about purchasing an Audi A3 8P, need some advice....
    Hi all,
    So I am thinking about purchasing the quattro 3.2 litre Audi A3 8P (04, 05 plate) and would really appreciate some opinions and feedback as to whether the 3.2 quattro is a good model to go for?
    Thank you,
    Chris.
    warren_S5's Avatar
    Oct 2007
    7,135
    It's a nice refined car, possibly a little nose heavy handling wise, but the best person to speak to would be Paddy as he had a 3.2 V6, and now has an S3 2.0T and can tell you the pros and cons of the 'V' lumped car against a 2.0T.
    There's also quite a few other owners on here who rate the V6 (e.g Sarah A3), and they really seem to enjoy the car and the drama the V6 engine adds.
    Audi S5 3.0V6T Coupe Black Edition
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Hi Chris
    My guess is you are driven by price which is why you have gone for 04-05 which is fair enough but it does limit your choice of other vehicles to compare a 3.2 against IE: a 3.2 will set you back £6k and an S3 double that at least. So...for the money They are a great fun car but it has to be said, if it goes wrong it will cost you a small fortune. For that reason it needs to be checked out before you buy and it "MUST" have a warranty so dealer only. If you spend £6k private and it has the dreaded cam chain stretch you have basically done your money !!!!! be warned.
    The V6 goes best with the DSG option ( and its quicker)
    It will only give 26mpg on day to day driving. less in traffic, a bit more on a journey if you are careful
    04/05 will keep you in the cheaper car tax band, £240 instead of £400
    05 might give you a one piece grill
    04 will be twin grill
    Mapping will not improve power noticeably but may smooth it out a bit
    Check insurance before you buy
    Radiators leak by that age
    The important thing is getting a good one. A bad one will be a nightmare and there are lots of bad ones about. Several people here have returned them for refunds because dealer will not fix them under warranty because the cost are more than the car is worth to them.
    Check it will hold 2k rpm rock steady in Neutral. Check it has no hesitation/misfires at 2k rpm on the road.
    Give it a short drive and get the fault codes down loaded. If it mentions multiple cylinder misfire or defo...camshaft set point not reached then run away !!!
    dont be put off, there is no point in me listing the good points which are many and a good one will be great fun but be under no illusion it probably will cost a lot to run. Its an Audi and the most complicated A3 at that by far ...
    HTH, feel free to ask questions.
    Arnie's Avatar
    Jul 2011
    London
    166
    If you are doing a lot miles in car get something with better mpg. If you drive like me, 1 tank every 2 weeks, just time to time then its a fun car and a lot cheaper tyan s3. Yes it is abit nose heavy. Service costs are almost the same as other audis, best to go to specialist rather than audi directly.
    I havent got more than 18mpg from the tank yet but I floor it at every junction I can find
    Daft Old Sod's Avatar
    Sep 2011
    14
    Drinks V-Power at a rate of knots, but the howl of that V6 as it climbs towards the red line makes it worth every penny. I also agree it's a wee bit nose heavy, but only really feel it when pushing hard through the twisties. Overtaking is a no brainer, couple of flicks of the left hand paddle, lean on the loud pedal, job done. A very lazy motorway cruiser to boot, 85mph at approx 3500rpm. Mine's a 2007 with DSG & I reckon it's the pick of the A3 8P's, but then I am a wee bit biased.
    wez3570's Avatar
    Jan 2011
    711
    They are a great car but as said, do your research first!
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    V Maxx plus coilovers
    Speedlines- anthricite
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    For Sale Genuine Audi phone cradle (iPhone 4S/4)
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I have never really understood the nose heavy thing. It depends what you are used to. As A3's go it is better balanced than any non quattro and better than a TDI quattro with its battery in the boot and its lack of Turbo and intercooler stuck up the front. People assume the V6 is heavy but it is actually one of the lightest and most compact available. I suspect the weight balance is one of these perpetuated myths.
    Bare in mind the S3 is a more powerful car then look at these times. 3 seconds in 80 is not a lot given the S3 is faster accelerating so i doubt the 3.2 lost out much in handling.
    Hockenheim Short 1:17.50 1:20.60
  1. Advice needed on purchasing a a3 Today
    By a3 quattr0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2011, 17:11
  2. Purchasing wiring looms from audi
    By *Müllërz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2011, 18:58
  3. A3 TDI purchasing advice
    By fizz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2008, 23:01
  4. Help me buy a S3 Sportback - purchasing advice req'd
    By RAPS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2008, 11:13
  5. Advice needed on purchasing this '01 Quattro Sport
    By chodecz in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2007, 11:47
