EM TuningBadger5
    rockape's Avatar
    Per ardua
    Dec 2010
    North East
    284
    Replacing bushes?
    Right then, I've decided to replace my dampers as I think they're a bit tired and I'm swaying towards the bilstein b8's(I have eibach springs) so making a b12 kit. Whilst having this done I'd like to change some of the suspension bushes to tighten up the feel of the car. However, I haven't a clue about which ones to change or whether to go oem,poly or a mixture.
    Any experts out there can help with some advice please?
    For sale:
    RS6 18" alloys
    S-line 8p2 chrome grill
    Pm me.
    Jul 2010
    53
    I am doing a similar thing to you I have spoke to a company called stealth racing and they assured me that I can upgrade to s3 bushes even though I have a front wheel drive 2.0tdi. They reckon poly bushes are a bit to stiff for hard road use. Im also putting on eibach anti roll bars which they reckon are a worthy upgrade.
    Aug 2003
    292
    I was thinking of changing mine when I change dampers as I'm trying to eliminate a nasty knocking sound when I go over potholes or speed bumps.
    I'm going to change to Koni FSD as the s line suspension is terribly hard.
    What would be the best bushes to get in order to give the softest ride even at the expense of handling or roll?
    rockape's Avatar
    Per ardua
    Dec 2010
    North East
    284
    I've read a few articles on this since posting and although the jury is out on the benefits of poly bushes its agreed they will give a more positive drive. The trade off is potentially an even harder ride. For this reason I think oem rubber bushes will keep some compliance in the chassis....after all thats why they're made from rubber is'nt it? Much cheaper too, especially after shelling out for shocks!
    For sale:
    RS6 18" alloys
    Pm me.
    Oct 2003
    up north...
    767
    I would stick to oem except for the front bottom arms where you can use polybushes to increase the caster (superpro) this increases the self- centering and dynamic camber on turns, which tends to improve the steering feel, reduce understeering by increasing front end grip and reduces the audi numb steering when driving straight-ish
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
  1. Rear axle bushes need replacing which ones to buy :)
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2011, 11:37
  2. Rear bushes need replacing, anywhere except audi to do it?
    By stevewushu in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2010, 10:39
  3. Replacing suspension Bushes?
    By reptor245 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2009, 23:14
  4. Replacing all bushes
    By vetch in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 20:08
  5. Replacing Bushes on an S3
    By 20valver in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2006, 10:31
