Results 1 to 13 of 13
    Dec 2007
    35
    Retro-fitting cruise control - Confused!
    Hello all
    I'm about to attempt to retro-fit cruise control to my 2004 3.2.
    The kit I have (from Audi) includes the replacement indicator stalk with additional cruise stalk, replacement trim and a wire, which the kit says, may or may not be required.
    My question is, how do I establish if I need to run the additional wire?
    The manual with the kit seems to be aimed at people who have a certain degree of prior knowledge on the system, which I don't.
    A Vag-com scan shows one controller as "Steering wheel - 1K0 953 549 A". I tried changing the coding of this controller to show cruise as being present (just a test - the stalk is not actually fitted yet), and it accepted the coding.
    Any help would be appreciated... I want to avoid having to do it by trial and error if possible!
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    337
    NHN or Jb0o will be around to help you out soon. These are both well known and certified jeaneouses.
    I'll make the call for you...
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Hi mate, as your steering module accepted the coding, you do indeed have the right module. Now to determine if you have the wire already installed, you need to check the back of your steering ecu, you will see two connectors. If there is a wire in Pin 13 of the black connector then you already have the wire in place.
    Remember you will also need to code the engine module in login to 11463.
    Check this link mate it has been discussed before
    Retrofit Cruise Control question (Slightly different one though)
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    As Danny said, Im also pretty sure you'll need to install the wire though with it being a 2004 Petrol.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Dec 2007
    35
    Thanks for the replies. I checked position 13 on the black plug to the steering controller and it was empty, so I put one end of the repair wire in it and then ran the wire through the plastic guide under the column as per the instruction manual. Now I'm stuck again! I can't find where to put the other end of the wire. The manual mentions a radiator coupling but this means nothing to me? I'm not sure if I have to feed the cable out into the engine bay or if it can be connected under the dashboard?
    Sorry to be a pain. I realise this has been asked many times before but I can't find a suitable guide :-(
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    It needs to be connected to PIN4 of a Blue Plug at the top of the dash board pretty much inline with the drivers side heater vent.
    Someone on the forum managed to put the wire into PIN4 using needle nosed pliers but I've found this impossible to do, the proper way, which is a bit of a nightmare is:
    - Remove the wiper blades
    - Remove Plastic scuttle panel
    - Unscrew wiper motor mechanism to revel a panel
    - Unscrew the two bolts on the panel, remove the panel to reveal the blue plug.
    - Disconnect the plug and push the blue connector that the plug was plugged into, into the dash
    - Fit the cable into PIN4 and connect everything back up.
    Job done
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    i used this guide when fitting mine:
    Retrofit Cruise - ESP problem
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by jb0o View Post
    Job done
    Let's hope the blue plug is there !!!!
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    Haha, I still have nightmares about that...
    Dec 2007
    35
    Thanks for the replies. I ended up taking the scuttle panel off in the end.
    I now have a steering wheel warning light and fault code of "steering angle sensor" and a series of beeps when i turn the ignition on, but I'm hoping I just need to run basic settings or something. (ran out of time to investigate before work)
    Thanks again.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    Dec 2007
    35
    Thanks jb0o. The warning lights/beeps actually stopped after 20 yards or so of driving, so I guess things just needed to get back in sync.
    I finished fitting the cruise control. I took the wipers/scuttle off to connect the aditional wire to the blue plug. For some reason, it's not working, though. Using the measuring blocks of the steering controller I can see that some of the cruise functions are being recognised (speed up and speed down) but it doesn't seem to register the set button.
    I noticed after a search on here that some controllers don't use the set button, but no matter what I do with the stalk, it won't work.
    I have recoded the engine ecu and it's showing a 'g' in the relevant field. I'm starting to wonder if I have the wrong cruise stalk.
    Anyone know if there is any way of checking with the engine ecu to see if it's receiving a signal from the cruise? I couldn't see anything in the measuring blocks.
    I have steering controller 1K0 953 549 A
    Thanks again.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Hi mate, the cruise will work different on yours being you have the older steering module.
    To activate ready for use- pull forward
    To set speed- click stalk down once (replaces pressing "set" button)
    Speed up and slow down- as on stalk
    To resume back to last set speed- click stalk up once ( replaces pulling stalk towards you)
    In measuring blocks with your module, it will only read speed up and down saying "accel" and "delay" and also "activated" and "off"
    Hope this helps mate.
  1. Cruise Control retro-fitting - can anybody on here for me?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2010, 18:54
  2. Retro Fitting Cruise Control
    By Morso in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th May 2010, 18:40
  3. Retro fitting cruise control
    By sixsr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd September 2008, 13:46
  4. Retro fitting Cruise control
    By sijones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2007, 10:14
  5. Retro fitting cruise control
    By Arf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2006, 12:30
