Volks AutosAH Fabrications
Results 1 to 10 of 10
    Oct 2010
    92
    Rear brake pad piston frustration
    Tried to change my rear brake pads today but had major hassles trying to wind the pistons back in. Don't have a special tool but the haynes manual reckoned you could use a pair of pliers to turn it - what a load of crock! Turned and turned and it wouldn't retract enough and spent ages using a combination of mole grips and a clamp. In the end a mate popped over and through the use of the clamp, grips and a hammer managed to get it to go back enough to fit over the new pads.
    Then tried the other side and had the same problem and have had to give up for the night, the piston just will not go back enough. I'm certainly not forking out £35+ just for the tool either seen as it would rarely be used.
    So what does everyone else do if they change their own pads, is there a tried and tested method without the use of the special tool?
    Oct 2010
    92
    Also managed to slightly split the rubber casing bit surrounding the piston, would I need to replace it?
    crunchie's Avatar
    Oct 2009
    Inverness
    861
    It is a nightmare job but £25 and the tool will out live you. Money well spent especially when you have to start changing seals!
    G-clamp and gland pliers usually do the job tho.
    BRAKE CALIPER PISTON REWIND WIND BACK TOOL KIT 34 PCS | eBay
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Apr 2009
    Florida (previously Liverpool)
    655
    Funny... Nobody wants to spend money for the tool that saves time, avoids frustration and sidesteps stripped piston threads, split boots etc.
    This is to work on BRAKES... Three things I don't skimp on: Tyres, Brakes & Steering.
    There are half-arsed 'cube' tools for five quid, but even they are a nuisance to use... Get the right tool is my suggestion. -You can loan it out to similarly-minded friends and have them pay you in beer... -And you won't split any more boots/seals.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,202
    Follow Brodster On Twitter Add Brodster on Facebook
    Same thing happened to me when I fitted Mintex brakes/pads on my last car and I had the proper tool.....easy to rectify though....it looks as though it might have a 'hydraulic lock' withing the piston. All you need to do is wind it the other way and you will find it rotates no probs. I even cracked open the bleed nipple but it wouldnt budge. Winding it in slightly solved the problem.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    You really need to change the dust seal if its split. If you get water in there it will rust and dirt will collect and eventually destroy the piston seal.
    Oct 2010
    92
    Didn't check ebay, only really halfords as it's the closest/quickest place to get one. They do seem much cheaper there though.
    And I wouldn't have attempted it had I known I needed a special tool - the haynes manual says if you don't have one you can use a certain type of pliers to turn the piston. When this didn't work I then tried the other methods as I wanted to get it done and clearly now can't use my car until it's sorted!
    Will have another look tomorrow and try and get the dust seal changed.
    L80EWY's Avatar
    Sep 2009
    331
    My dust seal is non existent now I've just noticed it when changing my pads anyone got a rear calliper going ? Drivers side ha
    dex140's Avatar
    Dec 2009
    190
    Same happened to me! had to buy the tool mid job......soooo easy with it tho!
    Oct 2010
    92
    Managed to get it sorted after borrowing a kit from a mate who works in a garage. Will not be attempting again without purchasing a tool next time! Will also ignore haynes manual tips if they're anything like this one!
  1. help neded with winding in rear brake piston
    By kevandalice in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2011, 17:00
  2. Rear Brake Piston clock wise or anti clockwise
    By Beardo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2011, 18:12
  3. can you buy a single rubber seal for the rear brake piston ?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th May 2009, 09:28
  4. HELP NEEDED WITH REAR BRAKE PISTON S3
    By oak16v in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2008, 18:54
  5. Rear Brake caliper piston tool
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2008, 11:29
