Sky InsuranceEM Tuning
    Aug 2011
    51
    Vmaxx coilovers slight knocking noise 2.0T quattro
    Well i fitted the VMaxx coilovers (not adjustable) to the car around 4 weeks ago, 2nd time at fitting coilovers so was pretty sure i was doing it correctly, however after fitting, the only was it can be described is the front mounts are loose, over small bumps that you should even notice, the front shocks seems to have play on the top mount..? a quess.
    I dont know if its all in my head but the noise is getting worse. I mean when i bought the car it was usual audi comfort, everything tight and a fine over bumps.
    I havent had time to check for play when jacked up, ive applied the brakes when going over bumps so its not the brakes.
    It could maybe be the locking nut on top of the shock, the plastic bit that came off the original shock.
    Maybe thats not super tight leavig slight play for when the car goes over rough bumps.
    One other thing it could be the bushes, but they were fine before lowering so i cant see why they would suddenly be worse than before.
    Going in to auditechinca hull friday they said they will go out in it and see what the problem is, would rather fix it my self but no time to take the shocks out again....horrid job.
    Anyway thought id share my story, if any one has experience with this please let me know :D
    Aug 2011
    51
    all is good, it was my bushes coilovers fine :D
    wez3570's Avatar
    Jan 2011
    711
    Quote Originally Posted by jakeward46 View Post
    What was the damage (££££) to sort it?
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    V Maxx plus coilovers
    Speedlines- anthricite
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    For Sale Genuine Audi phone cradle (iPhone 4S/4)
  1. JOM coilovers fitted, knocking noise at front (pics) help!
    By wez3570 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2012, 18:15
  2. Slight Knocking Noise - Opinions?
    By Geoff-R in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2011, 13:55
  3. Slight rattling noise after fitting coilovers
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2009, 10:46
  4. What is that slight knocking noise!?
    By Prince Ace in forum RS6 Forum
    Last Post: 21st January 2008, 12:09
  5. vmaxx coilovers????
    By rich-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2007, 19:19
