Monster MotorsportChris Nott
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    JLM or Powermaxx DPF Cleaner!!
    Come across these today on the web after I got my DPF light on, first time ever! Quickly cleared it with a 20 mile drive on M11 doing over 2k at about 70mph in fifth gear.
    How PowerMaxx DPF Power Clean - High Power Cleaner for Diesel Particle Filters Works
    The JLM diesel particulate filter cleaner is available in 2 versions. Diesel Partikel filter Reiniger gibt es in 2 versions. Diesel roetfilter reiniger is er in 2 versies.
    Just wanted to know if anyone has used this stuff. It says to add into tank before filling up and should last between 3-6 months. Apparently it helps burn soot at lower temperatures and helps regeneration a lot easier and keeps the DPF cleaner and last longer!
    Considering the DPF problems on 140's and especially 170's with a remap, maybe it is worth giving it a try?
    What is everyone's thoughts and opinions?
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Aug 2005
    West London
    850
    From what Ive been reading the soot needs to be burnt off at around 1000 deg C and the problem with diesels is they just cant get the exhaust that hot, apparantly its been a known problem for along time but emissions regs pushed DPFs onto the market before the technology was really viable. My brother used to work on busses and the solution to blocked DPFs there was to turn them around the other way so the soot got blown out anyway. If there was a magical solution im sure the truck and buss companies would be all over it.
    I cant see how anything can reduce the temp that soot can burn off but if your willing to give it a go report back on your findings.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    From what i can gather, is that it is an additive and that it helps break down the soot, therefore not needing as high temperatures to burn it off. The temp insinde the exhaust system does not actually decrease, but it is with the aid of the additive (dpf cleaner) that allows the soot to burn off easier on regen.
    Am tempted to try but this is the first time the warning light has ever come on in 5 years as most driving is mainly motorway, dual carriage etc..and has always done an auto regen.
    Maybe someone who has the light come on more frequent due to start/stop city driving etc.. will be able to give better results on this.
    Either way may add a can of this as i guess it won't harm the car.
  1. Longlife/JLM(DPF)/Vagcom
    By dantdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2011, 17:45
  2. Carpet cleaner
    By ScottD3 in forum Detailing
    Last Post: 24th March 2011, 07:41
  3. windscreen Cleaner
    By nugpot in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th March 2006, 19:35
  4. Window Cleaner
    By jesters3 in forum Detailing
    Last Post: 14th August 2005, 07:09
  5. Alloy Cleaner
    By eyecon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2005, 17:34
