Sky InsuranceBadger5
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By ScottD3
Thread: Air bag light on grrrr
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Angry Air bag light on grrrr
    My air bag is on had it scanned and it says drivers side igniter , does anyone know how much this will cost to fix as its doing my head in now lol and I want to get it done before the new law comes in for mot's , is it the kind of thing I could have a auto electrician do or is it audi only
    ​She is back on the road yay!!
    Lewis583's Avatar
    Mar 2010
    870
    Check the connections under the seat before you spend on new airbags. Make sure that the terminals are clean, tight and the wires aren't being pulled/stretched.
    You should be able to see them underneath the seat.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    the wires are ok checked them already
    netr's Avatar
    Jun 2010
    Ljubljana, Slovenia
    51
    Were you able to solve your problem?
    My warning light comes on and stays on for undetermined time (1 second - 3 minutes), then it comes off for few seconds (again undetermined). Also, when I started self-checking - clock/speedo cluster, the light came off, and it stayed off for 5 minutes.
    27,072
    Scan your car to see which airbag is at fault then trace it through.
    May 2010
    London
    334
    The sensor costs around £70/75, had to replace one of mine, easy job (if its the one im thinking of, under the bonnet, at the front)
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    scanned it well with the hand held device in work and it says drivers side airbag igniter , any ideas nige , not had chance to fix it yet no moneys spare lol
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by roman3000 View Post
    its the drivers side airbag on mine thanks for the info tho it all helps eh mate
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by netr View Post
    not as of yet mate no money spare right now will get it sorted one day hopefully lol
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    mine use to say that.
    I stripped the plugs gave it all a good clean, check and rebuilt it. Been fine ever since.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by scott b5 View Post
    what plugs dude the yellow one ?? , how would i go about stripping it easy job I'm willing to try anything once , tried unplugging it and plugging it back in a few times as advised by my mate who is a auto sparky
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by FranA3 View Post
    that's what I did first.
    not sure what they are on yours but on mine its the yellow and red/brownish on.
    tilt the seat back so you can see and have greater access to plugs.
    unplug them from the seat and make sure each contact is clean and shiny and no exposed cables (as said above).
    There should be a purple bit of locking plastic on the plug, remove this and depending on the plug, you should be able to remove the pin and cable to take a better look at its condition.
    when you got it all off its should be easy to see how they come apart.
    FranA3 likes this.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    cheers beaut will see what i can do hope it cures it , not tried undoing the battery yet either to see if that does anything prob won't tho as I've got the worst luck in the world lol
    27,072
    Check in the rear of the seat, have to remove rear seat panel, the connector may have come undone as it has another connector inside there aswell as under the seat, try checking all the connector pins for any corrosion, build up etc & scratch the pins either side to see if its a bad conductive point.
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    it is wise to disconnect your battery and leave for about 30 mins whenever you are working with air bags as last thing you want to do is short it out and set it off
    V8 baby... oh yeah
    27,072
    You'd like to think it goes without saying for Fran
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by Gavin0478 View Post
    Has that ever happened?
    Has any one actually set the air bags off by unplugging the cables?
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    would you really like to sit there and find out......
    this shows how much power their is in one!! Airbag prank gone horribly wrong - YouTube
    V8 baby... oh yeah
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    I've stripped and worked on enough and it has NEVER happened.
    I only ask cause I'm wondering if it has ever happened to any one.
    Its never happened to me.
    I've blow up a few. :D
    Videos :: air bag 2 video by Axios - Photobucket
    Videos :: Video004.mp4 video by Axios - Photobucket
  1. air bag light on and faulty brake light warning on dash ?
    By theviking in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th March 2010, 17:45
  2. air bag light and oil service light
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 11:49
  3. air bag light
    By stonecold1163 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2007, 21:13
  4. Air bag light
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2007, 10:46
  5. Air bag light !
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2005, 17:48
