Badger5Chris Nott
    reepers's Avatar
    Aug 2011
    Manchester
    110
    Alpine KCE-425 + RNSe Settings
    Hello Ladies and Gents!
    I have a RNSe and have got a Alpine KCE-425 interface fitted to allow video and ipod control through the headunit!
    This morning, it messed up put simply.... on the DIS instead of saying "POD" it had changed to "DVBT" and a black screen, along with the controls on the HU not working when the ipod is connected (couldnt even play music through the iPhone)
    What had happened was the settings had been reset to manufacturer default on the Kufa adapter (not a clue how!) - so to get it all back, this is what i did:
    1. Keep hold of the Setup button
    2. On the DIS you will notice it change to "CON" meaning Contrast, Press setup again and it will change to "BRI" = Brightness, again "COL" = Colour, again "XPO" = Horizontal placement of screen image.
    3. Hit setup again and it will read "RVC" = Rear View Camera Mode. You can activate this and deactivate it by using the big wheel - "RV01" = Activated, "RV00" = Deactivated.
    4. Hit setup again and it will read "1C" - this should be set to "1C00"
    5. Hit setup again and it will say "2C" - this should be on "2C18"
    Finally hit setup again, and it should read POD again!
    Not a clue if this will help anyone on here, but it took me a good few hours searching on the net to find this info and sort the problem out :-)
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    Very useful info. Don't have this fitted myself but it's on my very long to do list.
    the crisis mobile BMW Z4C 3.0
    It's quick and it sounds bloody good.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    I fitted this to my car nearly 2 years ago, worked very briefly then I gave up on it lol all the gear is sitting in the car - the kce, kufatec module etc...
    I will have to give it another go very soon, not overly fussed with it at the minute as I have dealt without it so I may put all the bits up for sale!
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Quote Originally Posted by Boydie View Post
    If you do decide to sell ......PM me.....I'll probably have it off you..
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    No probs mate - I will have a think about it and get back to you
    reepers's Avatar
    Aug 2011
    Manchester
    110
    They are annoying little buggers at times arnt they haha!! Would have got the AMI however i have the older RNSe
  1. KCE 425i to RNS-E install??
    By lionyo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th August 2011, 11:14
  2. IPOD INTERFACE! ALPINE KCE425 FOR RNSE
    By gaz m in forum For Sale/Wanted - Audi Parts
    Last Post: 20th June 2011, 01:47
  3. Parking System settings, Tyre Pressure Monitoring settings
    By AlexP in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2010, 00:13
  4. Serious iPod interfaces: Alpine KCE-425i, et al?
    By BahnStormer77 in forum In-Car Entertainment
    Last Post: 29th January 2010, 16:34
  5. Geniune AMG Alloys 17" 425-
    By imported_passat16v in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th October 2004, 20:11
