    Nov 2005
    UK
    586
    Details shown in central instrument display....
    Hi,
    I like have the range, temp and RNSE display ( radio station/ MMI playlist etc ) showing in my central instrument display, with Sat Nav directions taking over whe in use, but whenever I either turn off the Sat Nav or turn the RNSE until off at the end of the journey and then turn it on again at the start of the next, it defaults to Sat Nav ( even though I havent asked it to start route ) and seems to do this as standard, as my TTS with the same RNSE does the same thing.
    Is it possible to make the default display my preferred range, temp and music display by changing the settings, without having to press the right hand stalks 'reset' button three times each time I get in the car ?
    Hope that makes sense.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    I think it only does this if you have 'compass' selected in your RNS-E navi settings (NAV = SET UP = COMPASS). Mine is the same, always defaults to showing direction of travel on DIS on start up, but AFAIK only because I have 'compass' selected. Deselect COMPASS and the DIS display should stay as it is when you power down. Paula x
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Nov 2005
    UK
    586
    Thanks, i'll give it a try.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    You're very welcome, it should do the trick.
  1. Instrument Lights and digital Display wont light up!!!! A4 1.8TQS
    By muz_amin in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2009, 11:23
  2. instrument display
    By god-father88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2009, 20:05
  3. Speed on Central Display
    By rich32uk in forum You Tube Links
    Last Post: 6th January 2008, 12:09
  4. instrument display gone
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2005, 19:11
  5. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
