EM TuningVolks Autos
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Question Why am I getting an Error Code?
    I fitted my cruise control kit today and then did the coding as shown here:
    Cruise Control - Please can someone check the coding I've found is correct
    To be honest, the VCDS pop up screens tells you what to enter anyway.
    Everything went smoothly and the coding was simple and worked a treat. I did get the ESP fault on the DIS, but this went off after driving a few metres. The cruise works perfectly and everything is good. I then ran a full scan using VCDS and it brought up a fault with the steering controller, saying 'Incorrect Coding'. I cleared the codes and went for drive before scanning it again, but the same error showed.
    Should I be worried about this fault code, considering that everything seems to be working perfectly?
    Is it just that the coding is correct for having cruise control installed, but the controller thinks the coding is incorrect for my chassis number because it wouldn't normally have cruise on it?
    (The parts were bought from Huntingdon Audi, who confirmed that my controller will accept cruise).
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,109
    Hi mate, did you go to steering module "16" then go to coding and change the second last digit to "4"?
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Quote Originally Posted by Dannykn9 View Post
    Hi.
    Yeah I did. If I remember correctly it changed the code from 000012 to 000042. In the pop up window it said that '4' was for cars with on board computer and cruise control, which is correct for mine.
    Everything works fine, which is what's confusing me.
  1. Error code help please!
    By kev1000 in forum General Technical / How To
    Last Post: 26th September 2011, 13:45
  2. Help With Error Code
    By S3 Sly in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2011, 23:09
  3. Error Code help
    By fpscod in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2011, 17:53
  4. Error Code: 16985 - Internal Control Module: Memory Check Sum Error
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 11:34
  5. Error code...
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 14:47
